Old Thu, May-02-2019, 04:21:24 PM   #31
bimmers4life
bimmers4life's Avatar
Reputation: 0 bimmers4life is on a distinguished road
Default Re: Short shifter
Originally Posted by FK View Post
Where's my thanks?
Big thanks!
Jump to top bimmers4life is offline   Reply With Quote
Old Thu, May-02-2019, 07:15:51 PM   #32
Theef
Reputation: 0 Theef is on a distinguished road
Originally Posted by bimmers4life View Post
Got my auto solutions shifter installed and it is simply epic. I went with his auto cross kit and it is amazing. Everyone at the shop was asking about it. Highly recommend this route, I didn’t want a tall shifter either. This still uses my low zcp weighted shift knob
Did you replace anything else (bushings etc) while you were in there?
What did you actually get w/ your purchase? Lever, carrier, selector rod?
Jump to top Theef is offline   Reply With Quote
Old Thu, May-02-2019, 07:55:24 PM   #33
OldFanatic
19 yr BMWCCA Member
OldFanatic's Avatar
Reputation: 0 OldFanatic is on a distinguished road
the OP got a different version of the AS kit than me, but my 40% AS kit came with this years ago if this helps
2003 TiAg - OE CSL WHEELS - OE CSL BRAKES - AA SPORT TUNE - AA PULLEYS - AS 40% SSK- VCSL TRUNK - VCSL DIFFUSER
SUPERSPRINT EXHAUST
- BMW PERFORMANCE CF STRUT BRACE - BILSTEIN PSS9s - GRUPPE M CF INTAKE - CF RACE LIP - 4.10 M DIFF - CSL RACK - GROUP N MOTORMOUNTS
-SANS SUNROOF-
Jump to top OldFanatic is offline   Reply With Quote
Old Fri, May-03-2019, 05:42:40 PM   #34
spnsprt
spnsprt's Avatar
Reputation: 0 spnsprt is on a distinguished road
How hard is the AS install?
Jump to top spnsprt is offline   Reply With Quote
Old Fri, May-03-2019, 05:55:00 PM   #35
No more than any other SSK install. Smaller hands might find it easier. Getting the sect 1 out of the way makes it a little easier. A lift makes it easier. But, it's not too bad. I like to have some flat head screw drivers to help leverage the clip up and down and push the pins through and line things up.
The thing that is most helpful, IMO, is loosening the tranny brace and lowering the tranny a little bit like even a half inch or so. I support it with a jack.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · fan/SAP/washer delete · CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Fri, May-03-2019, 06:15:26 PM   #36
OldFanatic
19 yr BMWCCA Member
OldFanatic's Avatar
agreed. key word “Kit” in SSK. a simple lever is not as involved. i had a lift and have done it a few times so knew what to do. first timers expect to take a bit longer with the “b1tch clip”. it’s called that for a reason.
SUPERSPRINT EXHAUST
-SANS SUNROOF-
Old Fri, May-03-2019, 06:18:26 PM   #37
Theef
It's... beautiful.
I guess I'll have to email the owner to see if they still supply this kit. His poor website...
Old Fri, May-03-2019, 06:22:05 PM   #38
usdmej
i've never heard of the autocross kit. the only offerings outside of custom solutions he offered was 20/30/40% reductions. do you know why he started calling them that?
Jump to top usdmej is online now   Reply With Quote
Old Fri, May-03-2019, 06:38:22 PM   #39
bimmers4life
He makes a 20/30/40% kit that he calls his “ultras”. Then he has an Autocross kit that’s about 25%.
Call him on the phone and he will give plenty of detail
Old Fri, May-03-2019, 07:05:30 PM   #40
usdmej
i've spoken to him on the phone before and he built me a custom kit that i like a lot. just curious why he calls the 25% kit an autocross kit
Discussing Short shifter in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
