Old Sat, Apr-13-2019, 03:45:04 PM   #1
Eric M3
shogun
Eric M3's Avatar
Reputation: 0 Eric M3 is on a distinguished road
Japan
Default source for Bosch alternator diode rectifier pack?
Years ago on my 02/98 M3 the original alternator failed with only 28kmiles, battery light was always dimming, tested and found only around 10V with engine running, replaced voltage regulator, no change. Finally found out that 1or 2 diodes had died. Replaced the alternator with a 140A used one since then. Some years ago I tried to disassemble the rectifier to get to the diodes as these are available as single items. But the rectifier pack seems to be unserviceable, I cracked the housing and had to scrap the rectifier.
Now I am trying to rebuilt the alternator for stock and need a source and a part number for the correct rectifier diode pack, ETK does not show it as single item. I hope someone here on the forum knows a source plus correct part order number.
Data of the original alternator: Bosch 80A , BMW 12311744564, Bosch # 0 120 485 048. KC>14V 50-80A, Made in Great Britain, BMW # 1744562, Accdg to ETK new # 12311744562, 12341234667, remanufactured 12311744566
http://bmwfans.info/parts-catalog/E3...ctrical_system
Pics of the defective rectifier below.
Checked Woodauto in U.K. if they might have something, but ...apparently not
https://www.woodauto.com/group/82/RTF---Rectifier
On the other hand a new rectifier costs usually about $60, a reman alternator might be another option, just have to check and compare and then I decide.
The same Bosch alternator is used in E36 M50, M52, S52, M3 and in E34 with M50 engines, so there must be a demand for such rectifiers.
My 7 series DIY site: http://twrite.org/shogunnew/topmenu.html
Jump to top Eric M3 is offline   Reply With Quote
Old Sat, Apr-13-2019, 05:09:31 PM   #2
bluptgm3
Default Re: source for Bosch alternator diode rectifier pack?
The Bosch alternators are serviceable, which means, yes parts are available, however you are going to have to contact a rebuilder to source the parts.
Old Mon, Apr-15-2019, 02:34:40 PM   #3
Eric M3
shogun
Eric M3's Avatar
Japan
for future reference for this 80A alternator, offer is from a starter and alternator supplier in Poland, here more details on their website for the rectifier https://en.as-pl.com/p/ARC0031
ARC0031
Reference number Bosch rectifier
1127319009 BOSCH
1127319617 BOSCH
1127319623 BOSCH
1127320862 BOSCH
1127320882 BOSCH
and the pdf file there shows the Bosch alternator number same like my one
0120485048 BOSCH
012048504J BOSCH
0123100002 BOSCH
0123120001 BOSCH
0123310006 BOSCH
0123315004 BOSCH
0123320012 BOSCH
9120485048 BOSCH
9123320012 BOSCH
9123690001 BOSCH
Old Tue, Apr-16-2019, 09:39:16 AM   #4
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Why not replace just the voltage regulator?
Old Wed, Apr-17-2019, 01:24:06 AM   #5
Eric M3
shogun
Eric M3's Avatar
Japan
The voltage regulator is not the problem as mentioned in post # 1. V.- regulator was replaced against new one, but that did not solve the problem. Still no more than 10V and the battery light was always dimming. Replaced then the alternator against another one and all is fine.
We tested the rectifier and found defective diodes. That was already some years ago, now I just want to repair the original 80A alternator for stock.
The rectifier pack with the diodes pack seems to be unserviceable, I cracked the housing and had to scrap the old rectifier.
Now I am trying to rebuilt the alternator for stock and I was locking for a fitting rectifier diode pack for the Bosch alternator 0 120 485 048.
I am not in a hurry, still have one more used 140A alternator on stock, but want to repair the 80A one too.
Old Thu, Apr-18-2019, 10:26:53 PM   #6
bluptgm3
The early 105 A Bosch Alternators had these parts available from BMW
http://www.realoem.com/bmw/enUS/show...diagId=12_0487
Old Fri, Apr-19-2019, 04:55:55 AM   #7
Eric M3
shogun
Eric M3's Avatar
Japan
Thanks, that is a different alternator number than my 80A Bosch 0 120 485 048.
ONLY applies to BOSCH 0 120 500 970 BMW 12311730753/1735 403
08 Diode assy 12311735307
Part 12311735307 was found on the following vehicles:
3' E36   (11/1989 — 12/1995) 5' E34   (06/1987 — 06/1996)
when I search with that no. it also fits a 90A
ONLY APPLIES TO BOSCH 0 120 469 969 BMW 12311730752/1735402
http://www.realoem.com/bmw/enUS/show...00#12311735307
so, still not sure, anyway, I am not in a hurry, the now installed alternator works and I found another working 80A alternator from a parts car in my boxes, enough for the moment, just want to see what fits
Old Fri, Apr-19-2019, 05:55:58 AM   #8
M3AN
321 fun...
M3AN's Avatar
New Zealand
Any reason you're sticking with 80A? You can probably get a more modern 100-120A version for the same cost as the parts you're looking for...
/// E36 M3 Evo Coupe / Estoril Blue / Lotus White Individual
/// S50B32 / 6MT / Slick Top / Alu Doors / Z3 Rack / Simota / Remus / Bilstein / Eibach / BBS / Goodyear / Rally Road / 3.62 CWP (TBI)
Old Fri, Apr-19-2019, 08:45:09 AM   #9
Eric M3
shogun
Eric M3's Avatar
Japan
no problem at all. At the moment I have installed a 140A, just wanted to repair the defective 80A for stock.
But you are right, a rectifier costs abt $60, for a bit more I get a new cpl. and higher A alternator, should go that route when needed and just leave the defective one as is or use as core when buying a reman.
Old Fri, Apr-19-2019, 12:50:57 PM   #10
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
I doubt you would need that much amps.
It will also draw more power, although that may be marginal.
In the old days, according to my old E36 brochures, you got the bigger alternators when a carphone was installed. Back in the days these needed quite some juice to send signals to a tower.
Now there is a GSM antenna at every corner.
Discussing source for Bosch alternator diode rectifier pack? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
