Old Fri, Apr-12-2019, 08:06:41 PM   #21
Default Re: re-dye, re-upholster or leave them alone?
The eraser sacrifices itself too (this is how they work). Too much or too hard is bad, yes. Light thoughtful application can be OK. You’re trying to get the eraser to grab the junk out crevices other cloth types cannot. Also note, even cloth can damage the layers if used too vigorously.
Start with the mildest form of cleaning possible. Work your way up if needed and understand what reasonable correction can be achieved per your situation.
Old Sat, Apr-13-2019, 12:40:55 PM   #22
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Any thoughts on rubbing alcohol / isopropyl alcohol? I see this often mentioned in detailing forums.
Old Sat, Apr-13-2019, 03:02:52 PM   #23
Texaz3
Its a pretty aggressive solvent, do not use it on leather, or paint for that matter. Some plastics should be ok, I guess.
Old Sat, Apr-13-2019, 04:23:31 PM   #24
Earthwormjlm
Imolarot M3
Heavily diluted to under 20% concentration, isopropyl alcohol should be OK to use. Not as a primary cleaner, but to clean off any left over residue from whatever you used to do the main cleaning.
It's common to use it on paint too, as the final step before you apply a sealant, to ensure you have cleaned off all residue from polishing compound.
Old Sat, Apr-13-2019, 04:47:25 PM   #25
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Hmm good to know.
Intersting to see, as I some swear by it.
Old Sat, Apr-13-2019, 06:23:03 PM   #26
IPA is fine to use. I use it.
Old Sat, Apr-13-2019, 07:28:17 PM   #27
Texaz3
On leather? To do what - clean?
Old Sat, Apr-13-2019, 07:42:03 PM   #28
To strip off grease, yes. I dilute it and do wipe downs often with it.
Old Sun, Apr-14-2019, 05:08:57 PM   #29
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Today, just for fun I tried Alcohol Kentonatus 70% and even a little aceton on a wheel that I couldn’t be bothered with if things went bad.
Can say “wow”, but just see this:
That’s not light. I did the outside of the rim, not the back. The difference is just silly. It just came off with ease.
One thing though. When I see all the black gunk on my cloth, I do wonder if it’s gunk/grease/skinoil I’m taking off, or simply rubbing of the paint/dye. Which would make the result less nice.
Old Sun, Apr-14-2019, 05:23:32 PM   #30
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Ps Aceton is probably too aggressive, but just wanted to see what it would do.
Discussing re-dye, re-upholster or leave them alone? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
