Old Sat, Apr-13-2019, 02:19:44 PM   #11
///MonkeyTech
Reputation: 0 ///MonkeyTech is on a distinguished road
Default Re: E36 subframe
I have done some of the front subframe/crossmember reinforcements before. If yours is broke you would need to either replace it and weld in reinforcements or repair the cracked areas with good deep penetrating welds, and then add the reinforcement plates
Jump to top ///MonkeyTech is offline   Reply With Quote
Old Thu, Apr-25-2019, 03:17:06 PM   #12
Secniv
Reputation: 0 Secniv is on a distinguished road
Originally Posted by M3AN View Post
Hi from NZ!
"Subframe arms"? Do you mean the subframe cross member (under the engine mounts) or the engine support brackets (that sit on top of the engine mounts)?
The cross member doesn't have arms... but if there are cracks on the cross member where the engine mounts bolt up you can simply weld in reinforcement plates, no need to replace the whole thing.
Engine support brackets are unique to the engine and I was going to say the cross member was the same across all e36's but according to RealOEM the M3 part is unique also... I'm not sure what the differences are.
Thanks Dave
Have ordered some AKG reinforcement plates and once I drop subframe will check the welding job and cracks on the existing subframe. Iím at pick-a-part regularly so will take some measurements on a 6 cylinder car see if thereís any difference.
Jump to top Secniv is offline   Reply With Quote
Discussing E36 subframe in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
