Old Tue, Apr-09-2019, 10:38:35 PM   #1
Rich.7
Reputation: 0 Rich.7 is on a distinguished road
Default E46 M3 and Z4M seats weighed
E46 M3 coupe power seat with no heating and a Z4M seat power with no heating and here are the results:
E46 M3 Coupe leather seat, powered, no heat
60.4 lbs
Z4M Coupe leather seat, powered, no heat
56.8 lbs
Jump to top Rich.7 is offline   Reply With Quote
Old Wed, Apr-10-2019, 12:23:34 PM   #2
elbert
Sikkens Autocryl MM
elbert's Avatar
Reputation: 0 elbert has disabled reputation
Wales
Default Re: E46 M3 and Z4M seats weighed
Good info!
04 E46 M3
17 WK2 5.7
01 E46 325iT
Jump to top elbert is offline   Reply With Quote
Old Wed, Apr-10-2019, 02:44:16 PM   #3
stash1
Somebody was just selling a beautiful pair of Z4M Imola seats in the Marketplace that was very, very tempting!
'04 AW/IR...some mods
Old Wed, Apr-10-2019, 03:00:02 PM   #4
Rich.7
Those seats are a fair price, good value and are very difficult to find. The Z4M seats are much better and the best seats to getting before racing buckets. You should get them.
Old Wed, Apr-10-2019, 03:08:44 PM   #5
No way to get the tilt forward working with them though, right?
Old Wed, Apr-10-2019, 03:29:16 PM   #6
Rich.7
What do you mean? It's plug and plug. The powered seats have the same connections and motors with the exception of the older M3 models have different motor connectors so you would have to get a used wiring harness. Otherwise, everything else works fine.
Old Wed, Apr-10-2019, 03:35:21 PM   #7
FK
They don't tilt forward like the stock seats do because there is no rear bench in a Z4M. You basically have to slide the seat forwards.
I went with Recaro buckets with heat added in instead.
Old Wed, Apr-10-2019, 03:37:48 PM   #8
rockstar93
rockstar93's Avatar
Reputation: 0 rockstar93 is on a distinguished road
Referring to the "quick" tilt feature the E46 has to access the back seat, which the Z4M does not as it doesn't have a backseat. I've not seen anybody retrofit that feature, and because of that it's a much better idea to try and find a set of manual adjustment Z4 seats if you're going down this route purely for the convenience. If you were to electronically tilt the seat to get into the back, well it's a very slow process. This also means a greater weight savings.
Personally though, having owned both an E46 M3 and two Z4Ms, while the Z4 is slightly more supportive and "racy" feeling/looking, it's really not that comfortable. It lacks lumbar support/adjustment which is quite apparent on longer drives. Unless you were dead set on the OEM style, I'd spring for aftermarket seats.
Instagram
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 6MT Interlagos Blue/Fox Red
Jump to top rockstar93 is online now   Reply With Quote
Old Wed, Apr-10-2019, 03:55:51 PM   #9
Rich.7
Well the other thing is even after tilting all the way forward the opening is not as large. So A. not a family car but I wouldn't really care cause it's a coupe, and B. skinnier people are preferred for fitting through the opening for the rear seating.
I sit fairly upright with my lower back against the seat in all of my seats and feel much more comfortable even on longer drives. The only seats that are adjustable and comfortable that I like for an M car are the Recaro Sportster, which regardless cost significantly more then a used pair of Z4M seats. But it is subjective.
Old Wed, Apr-10-2019, 05:05:07 PM   #10
S54 Madness
S54 Madness's Avatar
Reputation: 0 S54 Madness is on a distinguished road
does anyone know the weight of E46 M3 Manual seats, leather, no heat?
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=234906&dateline=15265  73579
2001 M3 karbonius CSL Air Box / Alpha N-tune / American Racing Headers 6-1 Catted / Borla Sport Muffler /RE Race Pullies / Mishimoto Radiator & Oil Cooler / Ground Control Coilover Kit Street-School / StopTech Pads & Rotors / Apex Arc-8 / Dunlop Direzza ZII 265 Square Setup / Weight reduction down to 3,133lbs
My Build Journal
http://www.m3forum.net/m3forum/showthread.php?t=604716
Jump to top S54 Madness is offline   Reply With Quote
Discussing E46 M3 and Z4M seats weighed in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
