Old Tue, May-07-2019, 02:53:24 AM   #31
Nate047
Nate047's Avatar
Default Re: My 1995 Avus Blue M3 Coupe Project
Nice progress!
Old Mon, May-20-2019, 02:14:24 PM   #32
Steve M3
When I bought this car the passenger side skirt was missing. I was told that one would be ordered and painted, but that never happened so I decided to take things into my own hands. I found a deal on a used set, but of course they were the wrong color. I ordered some paint from automotive touchup as well as two part clear coat that comes in a can. I've never used the 2k clear before, but I have to say, I'm massively impressed with it.
Pretty hard to believe that this is a rattle can job.
I can't figure out if the paint is a shade too bright or if the rest of the car just needs a good paint correction, but it blends in pretty well since it's so low on the car. Overall, I'm happy for a home job.
Finally, a complete body again. The missing panels were driving me crazy
Jump to top Steve M3 is online now   Reply With Quote
Old Mon, May-20-2019, 04:02:42 PM   #33
Texaz3
I think the light/surfaces make it look different shade. Of maybe you didn't put enough clear/another layer of paint. Its hard to match new paint to a 20+ y/o paint.
Old Mon, May-20-2019, 04:08:52 PM   #34
mpwrcpe
The Throbbing Gristle
Reputation: 0 mpwrcpe is on a distinguished road
Avus, the only color that matters lol. Looks great!
__________________________________________
///'95 Avus M3 S54B32 Racecar
///'90 Calypso 325ic (70K miles)
///'72 Chamonix 2002 (Restoration project)
'15 Touareg TDI (Racecar hauler)
Jump to top mpwrcpe is offline   Reply With Quote
Old Mon, May-20-2019, 04:10:31 PM   #35
Steve M3
I think you're right. One more layer of paint might have done the trick but with the can starting to sputter, I didn't want to risk it. Either way, I'm extremely impressed with the spraymax 2k clear. That piece actually looks glossier than anything else on the car at this point
Old Mon, May-20-2019, 05:23:30 PM   #36
Texaz3
Was it one of those cans where you have to break the internal seal and mix the two parts before spraying? I've been using 2K urethane clears for a while, and they are great. Wear paint mask rated for organics and isocyanates when spraying though, they are odorless and colorless and will ruin your lungs in a jiffy.
Old Mon, May-20-2019, 05:34:20 PM   #37
Steve M3
Yes, that's the one. I used a 3M mask that I had from back when I used to spray paint through a hvlp setup so hopefully everything is good as far as filtration. I didn't take the warnings lightly as they were all over the can and the place I ordered from even had a specific agreement box that was required to check before ordering. Based on all of that, I expected it to be pretty good but not fresh out of a real paint gun good.
Old Mon, May-20-2019, 07:27:12 PM   #38
Texaz3
Just FYI at this point, but never use a paint mask that has been opened and exposed to air (not stored in airtight container) for ISO, these are technically one-time use masks (worn properly, good for about 6-8 hours). Even if this is a proper mask, filters are probably no good if it was opened more than a day or so ago. ISO is a very nasty stuff, and technically should be sprayed in full suit with oxygen-fed mask. Like I mentioned, it is odorless and colorless, and it gets in your body via skin, eyes, everything. Crazy shit. I used to paint a lot and did a lot of research on this.
Old Mon, May-20-2019, 07:37:09 PM   #39
Steve M3
That is good info for next time, thanks!
Old Fri, May-31-2019, 03:30:33 PM   #40
Steve M3
I started getting a really bad squeal at anything over 2k rpms all at once. I thought maybe the idler pulley was shot, or something along those lines, as the belt itself looked to have been recently replaced. I decided to slip the belt off to see if the idler pulley would spin freely and sure enough, it looked and felt brand new except for one oddity. The smooth pulley had lines on it from the belt itself.
I looked up the belt diagram and whoever did the cooling system had routed it wrong. Reinstalled it per the diagram and everything is super quiet now. I very rarely get $0 fixes, but I'll take it. I can't believe that it was able to be installed wrong and still keep somewhat proper tension on the system and not have interference anywhere, quite odd!
Discussing My 1995 Avus Blue M3 Coupe Project in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
