Old Tue, Apr-09-2019, 04:12:05 AM   #41
///M Dream
Real Madrid C.F.
///M Dream's Avatar
Reputation: 0 ///M Dream is on a distinguished road
Default Re: Avin Avant 4 Thread
Just ordered mine. LETS GO!!!!
Current: 2006 Interlagos Blue ZCP ///M3
Past: F80 M3. E46 330i ZHP. B8 S4. E92 M3. E46 M3.
Jump to top ///M Dream is offline   Reply With Quote
Old Tue, Apr-09-2019, 05:05:25 AM   #42
I M Legend
Originally Posted by 1/2past3ci View Post
Please excuse my novice question. I have an avant 2 installed in my M3 that I installed myself in 2014. It has functioned perfectly until I got my car out of storage this year. It is now inoperable. If I buy the avant 4 do I need to run all new wiring or will the wires in place work for a plug and play install? Thanks!
What issue are you having?
I also have an A2 and it's caught in an endless boot loop. Worked ok until this weekend.
I just don't see myself buying another AVIN based on all the bugs and work arounds folks have to do. Sad because generic units costing less than $100 function better. Too bad AVIN is the only one that looks OE.
Old Tue, Apr-09-2019, 12:04:03 PM   #43
1/2past3ci
Reputation: 0 1/2past3ci is on a distinguished road
Thatís incredible. Mine too worked fine until this weekend and I installed it in 2014. Itís caught in an endless boot loop as well. I donít care about half of the tech these are capable of. For me it has to be Bluetooth for calls and streaming and use google maps. Most importantly it needs to look like it could have been OEM.
Wes
Jump to top 1/2past3ci is offline   Reply With Quote
Old Tue, Apr-09-2019, 01:27:38 PM   #44
Originally Posted by lippstuh View Post
If you're like me and really want wireless carplay, an adapter is in the works and is set to be in stock by May 25.
https://www.aliexpress.com/item/Carl...983926178.html
I want that.
Old Tue, Apr-09-2019, 01:53:23 PM   #45
Jovica
Reputation: 0 Jovica is on a distinguished road
Hey guys,
Another A2 owner here which was working flawlessly for a few years and after pulling my car out of storage this week, it's also rebooting constantly - exact same behavior as what some others have described.
These instances must be related and are probably some sort of a software hick-up. Maybe programmed to fail after a number of years? Not cool. I will be reaching out to Avin shortly to find out what this could be.
Jump to top Jovica is offline   Reply With Quote
Old Tue, Apr-09-2019, 01:54:39 PM   #46
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
Wow i want that wireless CarPlay!!!
Can anyone post a video of their avant 4 startup time? Avant 3 took like 30 seconds which I thought was too long
Side note: Read through the description on the wireless CarPlay thing. Possiblythe worst google translate. Best one is "warm tip" Hilarious
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Old Tue, Apr-09-2019, 04:53:10 PM   #47
Hauptm
Reputation: 0 Hauptm is on a distinguished road
Originally Posted by Jovica View Post
Hey guys,
The identical issue with A2 for me starting this past Saturday. Worked fine since 2014 and now in an endless boot loop.
A bit too coincidental for my taste.
- Mark
'04 E46 M3 Vert, Silver Gray Metallic, Dove Gray, SMG
Jump to top Hauptm is offline   Reply With Quote
Old Tue, Apr-09-2019, 05:01:26 PM   #48
L0ADED
L0ADED's Avatar
Does it do update over wifi? A firmware update could cause this.
Old Tue, Apr-09-2019, 05:08:33 PM   #49
1/2past3ci
With mine I canít break the loop with anything other than putting the car in reverse which pulls up the rear view camera. All buttons wonít function.
Wes
Old Tue, Apr-09-2019, 05:45:48 PM   #50
Jovica
Hey guys,
Here's the response from Avin:
____________________________
Try disconnecting the GPS antenna from the radio. The GPS IC chip inside the radio might be causing the issue.
https://techcrunch.com/2019/04/06/gp...ght-get-wacky/
OR
You can try to perform a factory restore on the unit: Press the power button 8 times in a row and on the 9th press and hold the power button down for 3 seconds. This process can take up to 5 minutes to complete and will clear out the system and all user settings and apps will be lost.
If these don't resolve the issue, the GPS IC on the mainboard must be replaced is my guess. Not an easy thing to do and would probably cost more than buying a new radio considering labor cost to do something like that.
We are offering the all-new Avant4 BMW units to previous Avant owners for only $349.99
I've posed another question to Avin: 'If all else fails, can the GPS function be disabled to make the unit operable?' And the answer is: 'I dont think that is possible. The first thing I would try is to disconnet the GPS antenna from the radio unit.'
I don't have my car with me today so I'm not able to try the suggested steps until later this week.. so if anyone else can - that would be helpful.
Cheers
Discussing Avin Avant 4 Thread in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
