Old Sat, Jan-27-2018, 02:11:00 AM   #11
Euro Spec 73
Reputation: 0 Euro Spec 73 is on a distinguished road
Default Re: Driver's side door
Originally Posted by Haywood View Post
My driver's side door is getting harder to close. I have to use more force more and more. What is the cause of this and how do I fix it? Thanks for the help in advance.
What's happening is the striker on your door has a latch that latch seizes up after a while from being dried out from lack of lubricant one of the easiest things to do to fix this problem without removing it off the car and spending lots of money is to buy a can of lithium grease at any auto parts store then spray the latch with lithium grease thoroughly and after use a flat head screwdriver to manually push the latch back and forth back and forth so you don't end up damaging the door and once you see it goes back and forth freely with a flat head screwdriver enough times about 15 to 20 times or so then close your door normally and it should definitely see a difference after that point it should be back to normal if not look around for signs of rusting or if your door is sagging you might want to replace the door pin bushings that could be your second reason but the first is your best option and worst case scenario your Striker could be bad that's if the grease doesn't work or your pin bushings are bad.
I hope that helps.👍🏆🏁🏆
Jump to top Euro Spec 73 is offline   Reply With Quote
Old Sat, Jan-27-2018, 08:46:27 AM   #12
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Originally Posted by Eric M3 View Post
No problem here too with the doors.
If the doors close harder, often the case is a shrinking door gasket, that one can repair DIY, shown here on an E34 based on my idea https://www.bimmerforums.com/forum/s...pping-Seal-Fix
A shrunken gasket makes the door close more easily, for obvious reasons.
When I replaced the seals last year, it made the door close much harder untill they were ‘broken in’.
Discussing Driver's side door in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
