Old Thu, Dec-29-2016, 03:08:23 PM   #11
nasieg
nasieg's Avatar
Default Re: Finished my Recaro Sportster CS seat install with custom floor mounts
Originally Posted by Vmals89 View Post
Great work.
I thought the sportsters were 33lbs
I'm pretty sure it tipped the scale at 37, maybe it is a little heavier to to the seat heating? Be that as it may, I thought I had read 35 lbs before.
Interesting reverse of peoples normal issues-- normally people want to get the seat as low as possible!
I wonder if there's a compatible buckle receiver with a shorter run out there.
I know, and that is why I kind of went overboard explaining all the issues. I recognize that tall guys like to sit as low as possible to gain head room, but then you have the issue of sitting a bit to the left also. Unless your seat is so far to the rear, that you can move it back towards the inside? I have not explored that, since I would not sit in that position.
Yes, the seat buckle is an issue. It would be good to know if there are shorter ones out there. I definitely noticed on pictures of other installs that the stock buckle sticks out way too far if not mounted as low as possible.
Originally Posted by skillzo1 View Post
Looks great and clean.
Since we are on the sportster subject in here, has anyone ever removed the rear shell of these?
Not me. Why?
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Sportline CS8's, SG CSL Diffuser, OEM CSL Trunk
Jump to top nasieg is offline   Reply With Quote
Old Thu, Dec-29-2016, 03:22:15 PM   #12
skillzo1
skillzo1's Avatar
Reputation: 0 skillzo1 is on a distinguished road
Can sportsters be mounted without sliders?
Not me. Why?
Im having the rear shells done in either carbon fiber, blue csrbon kevlar, or painted piano black.
Current 05 IB//BL 6SPD 714RWHP 590TQ
SOLD 05 AW//IR 6SPD
Skillzo's Build...http://www.m3forum.net/m3forum/showthread.php?t=487768
Jump to top skillzo1 is offline   Reply With Quote
Old Thu, Dec-29-2016, 03:35:00 PM   #13
nasieg
nasieg's Avatar
Yes it can. You would probably want to go with a Planted Seat mount then. There are two concerns.
  1. You need to know exactly what seat position you want to end up whit and hopefully you can drill the holes in the seat mount just right. I don't remember exactly how that would have worked for me.
  2. The seat belt receptacle would be fairly high up in your lap and the bracket for mounting it that is welded on the mount might be in the way of part of the seat, depending on your seat position. I did not realize at the time though that you can remove the stock bracket from the seat and you could cut off the welded bracket from the mount and screw the stock seat bracket on instead.
Nice!
My Journal
Old Thu, Dec-29-2016, 03:41:39 PM   #14
You can order them in carbon rear shells directly from Recaro. Probably cheaper and better looking than a one off!
Old Thu, Dec-29-2016, 03:54:03 PM   #15
skillzo1
skillzo1's Avatar
Nice!
Last year i gave a quick shot at removing them and it didnt want to come off easy. It fealt like the plastic would crease or snap.
SOLD 05 AW//IR 6SPD
Old Thu, Dec-29-2016, 03:55:28 PM   #16
skillzo1
skillzo1's Avatar
Obioban seriously? I never new this. ...i searched google and never saw this. Couldnt even find the rear shells to purchase without cf.
SOLD 05 AW//IR 6SPD
Old Thu, Dec-29-2016, 04:00:03 PM   #17
yes
Old Thu, Dec-29-2016, 04:02:29 PM   #18
skillzo1
skillzo1's Avatar
yes
I know you could have this done upon ordering, but didnt know it can be ordered after to replace a non cf shell. I just emailed them.
SOLD 05 AW//IR 6SPD
Old Thu, Dec-29-2016, 04:49:57 PM   #19
Ah, I don't know if you can order just the CF rear shells, without the seats. Can't hurt to ask, though!
Old Thu, Dec-29-2016, 06:11:14 PM   #20
skillzo1
skillzo1's Avatar
ill report back
SOLD 05 AW//IR 6SPD
Discussing Finished my Recaro Sportster CS seat install with custom floor mounts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
