Old Sun, May-05-2019, 02:22:17 PM   #171
rbg
Reputation: 0 rbg is on a distinguished road
Default Re: Chach's DIY Porsche 996 BBK Conversion extensive write up
Looks great! Would you mind sharing the process and paints/chemicals you used? Thanks
Jump to top rbg is online now   Reply With Quote
Old Sun, May-05-2019, 04:05:05 PM   #172
Bimmerchop
Reputation: 0 Bimmerchop is on a distinguished road
Looks great, so are those front rotors 325mm then? Or you have the $800 ZCP sized (345mm) stoptechs?
Yooooooooo... Have you checked your inbox recently?
Am I understanding this correctly, people running the 345mm Front / 328mm Rear sized rotors with RR brackets are now running the D917 front pads at all four corners for both the front and rear calipers?
Rich | Flickr | Instagram | My AW/IR E46 M3 Journal
- AW/IR 6MT E46 M3
- JB/B 5MT E46 328i
- Ibis/Alcantara B8.5 A4 S-line
- Pearl Stg3+ B5 S4 (sold)
EURO.techniks
Jump to top Bimmerchop is offline   Reply With Quote
Old Sun, May-05-2019, 04:09:16 PM   #173
Engrmikl
Reputation: 0 Engrmikl is on a distinguished road
Doesn’t matter what color as long as the numbers match for our application.
Here is the ones I bought and some Brembo Decals.
Ok I was trying to be funny with the Red color and they seem to cost more. But I found out that the Red and Silver came only on the "S" type cars. But here is what I also learned and was wondering about because it kind of goes along with it. The last two digits on the full part number for these. The "modification" number. According to Porsche these are mods made to the caliper or whatever part. There are alot of differant ones. I am just going to use one as an example.
Front 996 standard end in "425 00" But there are options like a "425 21 or 22. The Boxster has several as well that are differant from these.
Anyone know anything about the differance? Probably doesnt matter but I like to learn stuff.
Edit
I am sure it means "S" or better
Jump to top Engrmikl is online now   Reply With Quote
Old Thu, May-16-2019, 04:29:48 AM   #174
duracellttu
Iím having some trouble finding Brembo decals. I donít know what size will for these calipers. Can somebody provide me a link for ones they use that fit? Iím looking for a black set. Thanks!
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Respray and Restoration: RKP Slicktop Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams | CSL Karbonious Airbox | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Thu, May-16-2019, 06:15:22 AM   #175
Post #150
http://www.m3forum.net/m3forum/showp...&postcount=150
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Fri, May-17-2019, 02:32:35 AM   #176
drp2014
Add Lightness
Reputation: 0 drp2014 is on a distinguished road
I used these and they got both front and rear perfectly
Brembo Brake Caliper HIGH TEMP Decal Sticker Set of 4 (Black)
Here is a pic of my caliper
Upcoming projects: EVOLVE carbon roof, Interior surprise
Services: Valve shim kit for rent, Valve adjustment in Virginia/North Carolina
Jump to top drp2014 is offline   Reply With Quote
Old Fri, May-17-2019, 04:18:03 AM   #177
duracellttu
Brembo Brake Caliper HIGH TEMP Decal Sticker Set of 4 (Black) Amazon.com: Brembo Brake Caliper HIGH TEMP Decal Sticker Set of 4 (Black): Everything Else
Thanks, ordered!
Old Fri, May-17-2019, 05:19:46 AM   #178
rbg
Guys while we are on it. Mind sharing your method if coating them? You go base powder coat, bake it for some time but not fully, then cool down a bit, then apply sticker and powder clear coat and fully bake? Am I missing something?
Old Fri, May-17-2019, 05:26:31 AM   #179
duracellttu
I am doing mine differently than this post. I have a base powder coat, then applying the sticker and get finishing with ceramic coating on top (CS-II).
Old Fri, May-17-2019, 05:38:26 AM   #180
At least for rattlecan method-
From my experience, you can change the color slightly darker with more baking between coats. To get the color as vibrant as possible, you'd only bake after the last clear coat for the time/heat stated on the can. This is for VHT/Dupli paints (the most ubiquitous). FYI, despite both being owned by the same company, their colors, VHT/Dupli, and not quite the same. I would experiment a little.
The key, if not baking the color coat before doing the clear coats, is to let the calipers dry for a while before applying the sticker. I would wait a couple of days at least if not longer, and that's in warm socal.
I like your idea of baking only a bit before the sticker. That would hasten the cure time. Especially if you don't want/need the brightest/most vivid shade of your color.
_
Discussing Chach's DIY Porsche 996 BBK Conversion extensive write up in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
