Old Fri, Mar-29-2019, 02:31:28 PM   #21
WALKD_U
WALKD_U's Avatar
Default Re: Best Adjustable Sway Bar Links?
Any other brand endlinks? I need to replace a set on my m3 (KW endlinks) Boots are torn. Wish there was some HD endlinks. Been going through then like socks...
Rides:
2005 AW/IR M3
BMB Stage 4
940whp/765wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
Instagram:
M3HNGRY
EURO.techniks
<a href=https://www.instagram.com/m3hngry/ target=_blank>M3HNGRY</a>
Old Fri, Mar-29-2019, 03:55:41 PM   #22
TostitoBandito
Reputation: 0 TostitoBandito is on a distinguished road
I've run the Turner links for years and they've been fine. There shouldn't be much stress on them if you properly dial out any preload.
Jump to top TostitoBandito is offline   Reply With Quote
Old Fri, Mar-29-2019, 03:59:37 PM   #23
unimpressed
Reputation: 0 unimpressed is on a distinguished road
You can look at McMaster Carr for rod ends and make yourself a set. I've found it cheaper than the automotive online stores. Quality is fine to, as my rod ends were QA1 and FK brands.
YouTube: MINIzguy Instagram: ndrewchow
Jump to top unimpressed is offline   Reply With Quote
Old Thu, Apr-18-2019, 02:04:35 AM   #24
Matte36
Reputation: 0 Matte36 is on a distinguished road
I run CATuned adjustable links. They’re satisfactory. Do the job they were intended to do and that’s that. Any solid or adjustable link will perform the same function as any other on the market. The durability and lifespan is the variable.
Jump to top Matte36 is offline   Reply With Quote
Old Thu, Apr-18-2019, 02:41:11 PM   #25
Gregarious7
Reputation: 0 Gregarious7 is on a distinguished road
Hey what's up guys. I know this is going to be a real n00b question but;
Do I need adjustable endlinks if I'm going from stock springs to H&R sport springs? Or do I need anything other than stock suspension if I go lower the car a bit?
thanks in advance yall
Jump to top Gregarious7 is offline   Reply With Quote
Old Thu, Apr-18-2019, 11:35:39 PM   #26
M3AN
321 fun...
M3AN's Avatar
New Zealand
Stock everything is fine if you're lowering only a little (up to an inch or there abouts). Especially if you're not installing adjustable suspension.
/// E36 M3 Coupe / Estoril Blue / Lotus White
/// S50B32 / 6MT / Slick Top / Alu Doors / Z3 Rack / Simota / Remus / Bilstein B6 / Eibach Pro+ / BBS RC / Goodyear F1 / Rally Road Bits / 3.62 CWP (TBI)
Old Fri, Apr-19-2019, 03:15:10 PM   #27
Gregarious7
Awesome. It's an inch in the rear, and 1.2" in front, so I should be ok.
Thanks M3AN!
Old Sat, Apr-20-2019, 04:19:40 AM   #28
Nate047
Nate047's Avatar
I have KW Clubsport coilovers with BimmerWorld adjustable links. They have (at least) 2 sizes so make sure you order the right size for your coilovers.
Old Mon, Apr-22-2019, 08:47:03 PM   #29
NolliM3
NolliM3's Avatar
I went with AKG...had to cut them to work with the BMW E36 318 26mm sway bar.
Discussing Best Adjustable Sway Bar Links? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
