Old Sat, Apr-18-2015, 01:25:36 AM   #81
Default Re: Going back to stock: OEM Style 67 18's
Yes, but that's too much, to your earlier point. Swapped you're in the 2.3ish range which is counter productive in my opinion.
-1.5 is ideal for aggressive street use, I've found. You get stock like wear and drivability but really good grip.
Agreed. Was just clarifying because you said "Max out the front camber".
Old Sun, Apr-19-2015, 04:12:41 PM   #82
albino09
Engineer
Well, tire choice (not size) probably has, by far, the largest impact on anything else - well maybe tied with camber.
That is to say - if you were to run a PSS 225 front you'd shit your pants at the increase in front grip you'd realize relative to what you have now. I've run the DWS and they are vastly.... hugely.... less grippy than a PSS, for example. They're also very imprecise, but that's a different story for another day. But they also ride dramatically smoother, so.....
A happy medium is the DW, if you think that will work for you. These are comfy but have pretty kick ass grip. Also - max out your front camber. This with better tires will make the car a real joy when pushing hard with zero (literally) negative side effects.
Or, just leave it alone and enjoy it for what it is
I picked up the DWS because we were headed into winter but I don't need true snow tires here in TN. Also, it was still on its original PS2s...
I guess I should be looking at tires before I get carried away. I'm a mechanical engineer by trade so I can really appreciate a factory feel intended by the OE.
Old Sun, Apr-19-2015, 04:21:25 PM   #83
EricSMG
40 something
Yes, thanks for the clarification as my post was vague.
That's how we learn, through experimentation. Yes, better tires before a single other change would be my approach.
Besides, square looks really awkward at stock ride height.
Current - 2017 F82 M4 ZCP DCT Blk/Blk Fully Loaded
Current - 2004 E46 M3 6MT SG/Black
Sold - 2018 F80 M3 ZCP 6MT AW/Black Cloth "stripper"
Old Sun, Apr-19-2015, 05:20:56 PM   #84
camberm3
camberm3's Avatar
Reputation: 0 camberm3 is on a distinguished road
Besides, square looks terrible at stock ride height.
Fixed
Jump to top camberm3 is offline   Reply With Quote
Old Wed, May-08-2019, 04:05:50 PM   #85
JuicyM3
Popopopop
Reputation: 0 JuicyM3 is on a distinguished road
2453 245 2445
and
265 rear?:?:? stagggeredrerd
thxx
EURO 2005 SMG | M-Texture Alcantara | Eventuri | Evolve Tuned | TD Pro Race 1.2 18x9 | ST XTA
Jump to top JuicyM3 is offline   Reply With Quote
Old Wed, May-08-2019, 05:24:32 PM   #86
u wot m8?
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer/fog delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Wed, May-08-2019, 07:11:16 PM   #87
HassanEido
HassanEido's Avatar
Lebanon
u wot m8?
Send it
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
385.7 whp 288 wtq
Old Thu, May-09-2019, 12:56:58 AM   #88
JuicyM3
Popopopop
I'm not even going to edit that... that's hilarious don't remember last night let alone what I was trying to post... sorry.
EDIT* I just remembered, so I've got coilovers and camber plates on the way, I've decided to stick with the OEM 18s for now until something comes along for sale.
I can't find any decent tyre in stock 255 40 18 currenty so wondering what's the best recommended staggered setup currenly? Also can't even get P4S in 18 inch here seems US only.
Old Thu, May-09-2019, 04:38:38 PM   #89
albino09
Engineer
I run 235/40/18 and 265/35/18 for my street tires (Kumho Ecsta PS91) and 255/40/18 square (Bridgestone Potenza RE71-R) for autocross on the stock 67's 8"f 9"r. The only downside to the 235/265 is they're nearly an inch shorter than the stock size, which only matters if you're at stock ride height like I am. 235/265 18s seem to have a lot of options, at least in the US. Can't really go wrong with any of the top brands available.
Old Thu, May-16-2019, 04:58:57 AM   #90
Goyo
Goyo's Avatar
Reputation: 0 Goyo is on a distinguished road
Wow ! This thread had come A long ways !
Well... I am not stock but I am squared !
Apex Arc-8 wheels and Michelin pilot super sport tires !
Cheers...
2004 E46 M3 MT
DD when raining: 2000 Toyota Hilux Surf MT
Gone but never forgotten: 2004 E46 M3 SMG, 2006 E46 M3 SMG, 2008 Skyline V35 AT
SMG? Read this...:http://m3forum.net/m3forum/showpost....28&postcount=9
Jump to top Goyo is offline   Reply With Quote
Discussing Going back to stock: OEM Style 67 18's in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
