Old Thu, Apr-09-2015, 05:53:36 PM   #21
EricSMG
40 something
Default Re: Going back to stock: OEM Style 67 18's
Stock sizes on stock wheels, all day err day. Nice and "full" looking. Handles amazing, more grip than you'll ever need on the street. Works great for AutoX, too.
Current - 2017 F82 M4 ZCP DCT Blk/Blk Fully Loaded
Current - 2004 E46 M3 6MT SG/Black
Sold - 2018 F80 M3 ZCP 6MT AW/Black Cloth "stripper"
Old Thu, Apr-09-2015, 06:30:12 PM   #22
Originally Posted by Goyo View Post
Thank you again.
So you have 18's on 225/35 & 255/30 with how much lowering...? And, on the same token, if going the 45/40 route, then do not apply any lowering? Hold, but then, what use to I have to the PSS10...? ;-)
Thank you Bear,
Well you hit the nail pretty good... Good chunk of the reason why I want to go back to 18's is to come back to a more classic look which IMHO the E46 M3 is getting into that classic classification already.
Folks, all joke aside, if I go back to full stock 45/40, what use to I have to the PSS10's?
Cheers,
G.
You can still lower the car with stock tires/wheels. You'll want 15mm/12mm or 12mm/10mm spacers F/R to complete the look. I would drop it around 3/4-1". Top of tire just touching the wheel well level. IMO.
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer/fog delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Fri, Apr-10-2015, 12:41:45 AM   #23
spawn_x
Reputation: 0 spawn_x is on a distinguished road
Armenia
wheel spacers are bad
function > looks
Jump to top spawn_x is offline   Reply With Quote
Old Fri, Apr-10-2015, 12:52:13 AM   #24
Cha5en
Reputation: 0 Cha5en is on a distinguished road
function > looks
What makes you say that?
Not sure you know the real purpose behind a spacer.
Jump to top Cha5en is offline   Reply With Quote
Old Fri, Apr-10-2015, 02:39:53 AM   #25
GarlicBread911
Reputation: 0 GarlicBread911 is on a distinguished road
function > looks
Why are spacers bad? Just the added weight? Genuinely curious.
Jump to top GarlicBread911 is offline   Reply With Quote
Old Fri, Apr-10-2015, 02:58:21 AM   #26
M3_Ed
M3_Ed's Avatar
Reputation: 0 M3_Ed is on a distinguished road
IMO, I hated the stock staggered setup in autox, under-steered like mad mid corner then would break into snap over-steer. Was a bit better after I put 15mm spacers up front (looked a bit goofy) but still under-steer and ate tire shoulders. Moved to a 9.5" square setup and it was much better, car is completely neutral now.
I would probably still have my 67's if one of them didn't crack. But I agree, on the street the 18's were great, if you're hitting their limit on the streets you're probably driving recklessly.
2002 M3 CB Coupe 6MT|||
M3_Ed's Journal RIP
The Resurrection M3 Touring Build
Jump to top M3_Ed is offline   Reply With Quote
Old Fri, Apr-10-2015, 03:31:25 AM   #27
Spacers are a necessary evil, in a way, if you're going to run wheels with mild offsets like OE wheels.
No, you'd rather not have them, but it's not that bad. Clean your hubs' face and lips, get proper spacers, tighten the wheel properly (unloaded) and you'll be fine.
Old Fri, Apr-10-2015, 03:43:01 AM   #28
spawn_x
Armenia
You are adding something in between the wheel mounting surface and the rotor / hub, you are adding stress and weakening the assembly, and more than likely putting additional wear on your suspension (then again I think a real low offset also puts additional wear)
I know tons of people run them without any issues on street and track, and have far more horsepower and push their cars way harder than I ever will, but it doesn't change the fact that its just not right
For most the pro's outweigh the con's, but my personal opinion / advice is to avoid them
my 2 cents, no flaming, we are not 17
Old Fri, Apr-10-2015, 03:49:54 AM   #29
oepuxuntom
Reputation: 0 oepuxuntom is on a distinguished road
However all I see are wide wheels and square setups.
LOOK COOL
Jump to top oepuxuntom is offline   Reply With Quote
Old Fri, Apr-10-2015, 03:54:59 AM   #30
spawn_x
Armenia
square you will definitely need spacers, unless you are one of the few that run different offset front/rear and rotate tires and not wheels, which is what I would personally do
(but I am a poser and want a wider rear )
Discussing Going back to stock: OEM Style 67 18's in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
