Old Wed, Apr-08-2015, 07:15:39 PM   #1
Goyo
Goyo's Avatar
Reputation: 0 Goyo is on a distinguished road
Default Going back to stock: OEM Style 67 18's
Folks,
Thinking really hard to go back to stock OEM Style 67 18's and would like to hear your advice: What would be the best set up in your opinion for the OEM 18's? I have read / heard that running 35 or 30 sidewall for 18's is best. Is this still true? Also, how much lowering is enough without looking gang?
Thank you very much,
G.
2004 E46 M3 MT
DD when raining: 2000 Toyota Hilux Surf MT
Gone but never forgotten: 2004 E46 M3 SMG, 2006 E46 M3 SMG, 2008 Skyline V35 AT
SMG? Read this...:http://m3forum.net/m3forum/showpost....28&postcount=9
Jump to top Goyo is offline   Reply With Quote
Old Wed, Apr-08-2015, 07:58:04 PM   #2
Default Re: Going back to stock: OEM Style 67 18's
Run stock tires with stock wheels. Duh (sorry).
225/45/18
255/40/18
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer/fog delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Wed, Apr-08-2015, 08:24:12 PM   #3
ECB
ECB's Avatar
Reputation: 0 ECB has disabled reputation
Depends on what you're looking for. Here's mine with square 9" wheels, 10mm spacer in rear, 265/35 front, 275/35 rear. H & R springs.
2004 M3 / 2003 M5 / 2007 Porsche 911 turbo / 2016 428i
Jump to top ECB is offline   Reply With Quote
Old Wed, Apr-08-2015, 08:29:16 PM   #4
Voss
Function over Form
Voss's Avatar
Reputation: 0 Voss is on a distinguished road
What tires are you running?
Jump to top Voss is offline   Reply With Quote
Old Wed, Apr-08-2015, 08:56:52 PM   #5
Cha5en
Reputation: 0 Cha5en is on a distinguished road
I have my summers about to go on 235/40 265/35
12 spacer in the front, 10 in the rear
Jump to top Cha5en is offline   Reply With Quote
Old Thu, Apr-09-2015, 01:08:57 AM   #6
spawn_x
Reputation: 0 spawn_x is on a distinguished road
Armenia
I think the 18s look pretty good, and the stock tire size is pretty good as well unless you got racecar horsepower or track the thing.
My gripes with stockers are weight (mainly) and BBK clearance (don't have yet)
If the right set of aftermarket light wheels comes up in stock size/offset, I'm probably going to pick them up just to shave off 5-6lb per corner
However all I see are wide wheels and square setups.
p.s. I do will not run a spacer
Jump to top spawn_x is offline   Reply With Quote
Old Thu, Apr-09-2015, 01:18:05 AM   #7
bimmerfan08
bimmerfan08's Avatar
Look like Michelin PSS
"The most difficult part of figuring out a car, the engineering, has been accomplished. Repairs and maintenance are simply dissembling parts and reassembling them." - bimmerfan08
Old Thu, Apr-09-2015, 02:20:35 AM   #8
Cha5en
Can we get a reputable wheel company (Apex Cough) to make a OE 18 that weights 5 pounds per wheel less?
Old Thu, Apr-09-2015, 02:45:01 AM   #9
djjvr
OEM+
djjvr's Avatar
Denmark
I love the look of those wheels with the spacers! Off topic, but were those refinished? They look brighter than stock.
"I can't dance, but I can drive stick."
Build Journal Instagram
Old Thu, Apr-09-2015, 03:30:16 AM   #10
KhanArt
CLEAN & SIMPLE
KhanArt's Avatar
Not my car but I love this guys set up. Love it!
Build///Journal
IG: @Khan_Art_
Discussing Going back to stock: OEM Style 67 18's in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
