Old Thu, May-09-2019, 09:09:17 PM   #771
ATB88
Reputation: 0 ATB88 is on a distinguished road
Originally Posted by HDdave View Post
Yeah I thought about diff bearings too.. But I figured I would stop at the seals. Iím so damn busy at work, and trying to get my boat ready for offshore fishing/ island hopping this summer too. Had to cut myself off somewhere.. About to tackle this wiring tonight after I clean the truck.
Hahah yeah I hear you. Even with everything that I did, there were still little voices in the back of my head saying "just drop the subframe and do the bushings... the diff's already out! weld in plates!!!" smgdh lol
Jump to top ATB88 is online now   Reply With Quote
Old Thu, May-09-2019, 09:20:37 PM   #772
HDdave
HDdave's Avatar
Reputation: 0 HDdave is on a distinguished road
Yeah i am hoping it is worth dumping all this $ into a 150k mile car but i guess we will see.. Not to concerned about getting any kind of return out of it ever though.
EDIT: Huge shout out to all yall that made this thread possible. Honestly that wiring was easier than doing a basic head unit install with all these instructions. Might have taken me an hour if that.
2003 TiAg 6mt- VMR 710ís, PS4s, Dynavin, Bavsounds, Coby Wheel, AFE, Angel Eye Guy, VAC, Mishimoto
16 Denali HD Duramax Stone Blue Metallic- Toyo 35's
Jump to top HDdave is offline   Reply With Quote
Old Sun, May-12-2019, 12:30:07 AM   #773
Angelom3vert
Reputation: 0 Angelom3vert is on a distinguished road
No problem, just paying forward all of the help that I got here when I was troubleshooting my swap :]
Good luck finishing it!
Question , where do u plug the new gps sensor? I cant find a plug for it .. the only one that first is the one from backuo switch
Jump to top Angelom3vert is offline   Reply With Quote
Old Sun, May-12-2019, 03:45:41 AM   #774
yopikari
Reputation: 0 yopikari is on a distinguished road
There isn't another plug that directly fits the GPS, you will need to modify the connector by trimming the plastic in order to make it fit. On the SMG harness there should be two identical plugs, one goes to the reverse sensor, and the other goes to the GPS.
Jump to top yopikari is offline   Reply With Quote
Old Sun, May-12-2019, 04:09:35 AM   #775
Angelom3vert
I only see one plug
Old Sun, May-12-2019, 05:50:03 AM   #776
yopikari
I only see one plug
Someone can correct me if I'm wrong about this, but I believe it is the plug that used to go to one of the sensors on the bellhousing, since you no longer need them to be plugged in.
Old Sun, May-12-2019, 06:12:44 AM   #777
Angelom3vert
Ohh so the one from the bellhousing is the one i use for the gps sensor?
How do i know wichone i need for reverse and gps ??
Old Sun, May-12-2019, 06:36:56 AM   #778
yopikari
Yes! It should be pretty clear which of the two bellhousing connectors you use for the GPS, but it will still need to be trimmed slightly to make it fit. The longer of the two goes to the reverse, and the shorter goes to the GPS. I believe that only one of them reaches the reverse sensor anyways.
Old Sun, May-12-2019, 06:42:45 AM   #779
Angelom3vert
Got it thank you . Made a rookie mistake and install tob before fork , had to remove transmission for a second time because the pedal wasnt moving lol oh well . Lol
Old Sun, May-19-2019, 08:18:27 PM   #780
DRockM3
Reputation: 0 DRockM3 is on a distinguished road
Hi all, still struggling with my last piece of conversion: PDC/Mirror tilt. I can't get it working.
Car is a 2004.
All coding and programming mentioned in this thread has been completed successfully. SMG ECM has been removed. Cruise works perfectly.
I've successfully connected PIN 7 on cluster connector(X11176) to connector/bus X428 at the fuse block. I've triple checked the connections and 12v signal at cluster when in reverse.
Any thoughts or leads from the 03.5+ crew?
Jump to top DRockM3 is offline   Reply With Quote
