Old Thu, May-16-2019, 04:27:29 PM   #1
Mpowerzz
Reputation: 0 Mpowerzz is on a distinguished road
Default supersprint resonated section 2 vs stock section 2
For those who had a supersprint resonated section 2. Why did you go back to stock section 2?
Jump to top Mpowerzz is offline   Reply With Quote
Old Thu, May-16-2019, 04:45:10 PM   #2
Default Re: supersprint resonated section 2 vs stock section 2
Because it guts the midrange and is a bit drone-y.
/// 2004 SilberGrau M3 Coupe 6MT slicktop zero options <3200lbs JOURNAL
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer/fog delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Thu, May-16-2019, 05:40:57 PM   #3
kmfurdm
Oceania
kmfurdm's Avatar
Reputation: 0 kmfurdm is on a distinguished road
England
For me it was mostly to cut back on the drone. Not that it was horrible. Just more than I wanted to deal with.
evolve-R -- AFe Stage 1 -- Turner pulleys -- SuperSprint V2s -- Euro Section 1 -- Dinan muffler -- TC Kline D/A 500F/500R + TCK Camber Plates -- autosolutions 20% SSK -- Volk RE30 Hyper Bronze
Jump to top kmfurdm is offline   Reply With Quote
Old Thu, May-16-2019, 06:34:22 PM   #4
Mpowerzz
ok, I got a eisenmann sport muffler and it drones. So I won't be adding the supersprint section 2, I don't want more drone.
Old Thu, May-16-2019, 07:23:38 PM   #5
Mr.wReckless
Mr.wReckless's Avatar
Reputation: 0 Mr.wReckless is on a distinguished road
Norway
From my endless youtube exhaust searches it seems the x-pipe version of the section 2 is the one to have to get a bit more of an exotic sound out of the S54? Resonated in my case as I don't see the charm in just a LOUD exhaust and firmly believe that the measure of a quality sounding exhaust is much more than it's loudness.
Regards
Jump to top Mr.wReckless is offline   Reply With Quote
Old Thu, May-16-2019, 07:30:37 PM   #6
Mpowerzz
Resonated x pipe is the one I have, Don't know if I should install it, I also have a cpi catted and resonated section 1, that I will install. That might help with the drone, When I had it on the car before, it killed all rasp.
Old Thu, May-16-2019, 07:56:57 PM   #7
kmfurdm
Oceania
kmfurdm's Avatar
England
That was another reason I switched back to the stock section 2. I wanted some of the rasp back.
Old Thu, May-16-2019, 08:28:31 PM   #8
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Depends on which Supersprint Section 2.
Originally I had the Supersprint Resonated X-pipe. I like it a lot. That being said, while it cut down on the rasp (not a total elimination in my case) it DID increase in-cabin drone. For larger power builds, the 3" single pipe also becomes restrictive. I swapped bothy my Supersprint Resonated X-pipe and RE Muffler to the new Oversized Resonated Supersprint Twin-Pipe section 2 with an oversized Supersprint Street muffler. With that change, Rasp is totally gone from being audible in the driver seat, and there is no in-cabin drone to speak of. With the new muffler and section 2 combo, the volume is more like the loudness with the stock muffler. I also noticed a healthy bump in power switching from the first setup to the second.
My two cents -- If you are looking at section 2 options, I recommend the newer Supersprint Resonated Twin-Piped Oversized section 2 over the X-pipe or any other section 2. I'm not aware of anyone being unhappy with the outcome after this upgrade.
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized HJS Race Catted section 1, SS 2.5" Twin-Piped Oversized Custom section 2, Custom Oversized Supersprint muffler, Catcam's Billet 280/272 cams, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Brembo GT6 (front) + GT4 (rear) BBK, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, SMG Pump Relocated.
For Sale: BNIB OE CSL Wheels
Active Group-Buys (PM if Interested):
Camshaft Group-Buy, OE CSL Bootlids, Supersprint Headers/Exhaust thread, New Supersprint Oversized Twin-Piped Section 2
Old Thu, May-16-2019, 11:13:16 PM   #9
usdmej
Reputation: 0 usdmej is on a distinguished road
Regards
section 2 only controls overall volume and to a lesser degree rasp
Jump to top usdmej is offline   Reply With Quote
Old Fri, May-17-2019, 01:43:50 AM   #10
STAATS
STAATS's Avatar
Reputation: 0 STAATS is on a distinguished road
Is this actually true vs stock Sect 2?
I thought it had documented gains which were only trumped by the BW 3.5" setup and now by the new dual SS 2.5" Sect 2 setup?
STAATS
BMW E46 M3 Vehicle Log Book & Service Tracker Tool: http://www.m3forum.net/m3forum/showthread.php?t=564731
BMW E46 M3 Vehicle Data Record & Modification Journal Template: http://www.m3forum.net/m3forum/showthread.php?t=566440
2003 BMW E46 M3 Street / Road Rally Build: http://www.m3forum.net/m3forum/showthread.php?t=566468
Jump to top STAATS is offline   Reply With Quote
Discussing supersprint resonated section 2 vs stock section 2 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
