Old Wed, May-15-2019, 03:23:34 PM   #11
Texaz3
Default Re: Dealer says thermostat needs replaced
Originally Posted by WOLFN8TR View Post
$775 to change a $50 Tstat? I just replaced my entire cooling system for around the same price. Radiator, Pulleys, Belts, Water Pump, Tstat, and installed a Electric Fan with N15 mounts.
^ This. Its one hour job, maybe less.
“Aerodynamics are for people who can't build engines.” - Enzo Ferrari
Old Wed, May-15-2019, 03:25:23 PM   #12
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
Sounds like your fan clutch is bad. Ya the Tstat is easy just DIY.
Build Thread - S54 Vanos Thread - Hi-Temp Oring Kits!
BAVSOUND Stage 1 - UltraGauge - Valentine One - Orion V4's - ARC-8's
TTFS Engine/SMG Tune/CSL 255 - SGT Headers/Sect 1/SCZA - Evolve Eventuri
VIS XTS CF Hood - CF Lip/Console/Diffuser - OE CSL Trunk - BWS 500S 9k/11k
Jump to top WOLFN8TR is online now   Reply With Quote
Old Wed, May-15-2019, 03:54:40 PM   #13
M3GA
Reputation: 0 M3GA is on a distinguished road
If you're planning an overhaul anyways. Do it sooner than later.
Fan clutch and t-stat seem appropriate to keep you going strong.
Sent from my SM-G960U using Tapatalk
Jump to top M3GA is offline   Reply With Quote
Old Wed, May-15-2019, 04:37:40 PM   #14
DJAM3
DJAM3's Avatar
Reputation: 0 DJAM3 is on a distinguished road
When I got my airbag recall done the dealer quoted me something crazy like $1000 for a valve cover gasket . I already had a OEM gasket at home and changed it for maybe $70.
Jump to top DJAM3 is offline   Reply With Quote
Old Wed, May-15-2019, 05:01:13 PM   #15
JamesSJ1
Reputation: 0 JamesSJ1 is on a distinguished road
Originally Posted by Whitehawk8 View Post
Highly recommend you try it yourself. Super easy to do.
$40 part. Buy the Wahler brand one - its OE.
Like wolf I replaced my entire cooling system for about that price
The dealer said my freshly flushed brake fluid needed to be replaced. Literally flushed a week before...
^THIS is why people need good indy shops, and avoid the dealers.
Jump to top JamesSJ1 is offline   Reply With Quote
Old Wed, May-15-2019, 05:02:31 PM   #16
Whitehawk8
Whitehawk8's Avatar
Reputation: 0 Whitehawk8 is on a distinguished road
These cars are really a breeze to work on if you would rather.
I too stopped by for my airbag recall but they did their 120 point inspection or whatever.
2003 M3 StahlGrau Metallic | Beisan | JB Racing | Koni | CMP | TMS | OEM SSK
Jump to top Whitehawk8 is offline   Reply With Quote
Discussing Dealer says thermostat needs replaced in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
