Old Tue, May-14-2019, 10:11:40 PM   #41
Kenny167
Reputation: 0 Kenny167 is on a distinguished road
Default Re: At my wits end, misfire issue, OBDII monitors incomplete...
Care to explain what can be “coded” on the mss54 rather than tuned? I’m quite certain there’s no distinction of that sort on this dme.
I was thinking about how the other modules worked and wasn't completely focused on what I was saying, I meant that it's not a part of the maps/scales but rather an option being flipped on or off.
Jump to top Kenny167 is offline   Reply With Quote
Old Tue, May-14-2019, 10:33:49 PM   #42
CSLM3Wannabi
Reputation: 0 CSLM3Wannabi is on a distinguished road
Default At my wits end, misfire issue, OBDII monitors incomplete...
^ this
2005 BMW M3 ZCP Nardo Gray | ESS VT2-550 | Dinan Throttle Bodies | 6MT Swap | Active Autowerkes Headers + Section 1 w/ 100 cells | Miltek Section 2 and 3 | KW V2 w/ GC camber plates and Eibach Front and Rear Swaybars | Porsche 996 BBK upgrade w/ OEM ZCP rotors | Umnitza V4 Angel Eyes | Euro bumper w/ Morimoto led fogs | 1 piece Carbon Lip | VIS XTS Full carbon hood | SCZA Carbon Fiber CSL Trunk | Carbon Fiber CSL Diffuser | Square ZCP Wheels |
Jump to top CSLM3Wannabi is offline   Reply With Quote
Old Tue, May-14-2019, 10:47:02 PM   #43
alwaysbored786
Reputation: 0 alwaysbored786 is on a distinguished road
Hey look I was on the right track
I don't think it's leaking capacitors, because why would it change when the engine warmed up? I guess the idle is controlled differently but I doubt that's the issue.
The reason I say that is because the oxygen monitor shows incomplete, which tells me that in one way or another the ECU is getting bad info, or it's getting info and interpreting it as bad. This is likely due to the coding of the ECU (not the tune, but coding), which would explain why it worked with the other ECU.
If I were you, I'd check the different parameters I mentioned previously (mainly the cat protection and SAP cat heating) and see what's different between your ECU and the one you dropped in. If they're different, fix it, and if not, then continue the search...
Im with you on this one, but i'll check just to humor them so they can get to fixing my tune ASAP.
Originally Posted by CSLM3Wannabi View Post
You are more than likely correct, sir. Being that there are no issues once the warmup cycle has finished it is most likely a coding issue. However, the coding, I assume was done along with the tuning, leaving the tuner responsible for the repair. Last thing I want to do is mess with someone else’s work. Just happy I could be of assistance.
Indeed, they need to be the ones to fix this for sure, onus is on them if my capacitors are indeed not leaking. Thank you again for all of the help man, hopefully my car will be running misfire free soon enough!
Current Stable:
2006 ZCP M3, Interlagos Blue/Black, 6MT
1998 M3 Coupe, Black/Black, 5MT, 28K miles
1996 M3 Coupe, Techno Violet/Hurricane, 5MT
Gone but not fogotten:
1997 M3 Coupe Techno Violet/Mulberry 5MT, 2004 Noble M12 GTO 3R 6MT, 1996 XJ Red/Tan AT, 1995 M3 Coupe Silver 5MT, 1988 325e Black/Black 5MT, 2002 330ci Blue/Grey 5MT, 2003 ZHP Sedan Black/Black 6MT, 2003 M3 Imola Red/Black 6MT
Jump to top alwaysbored786 is offline   Reply With Quote
Old Wed, May-15-2019, 01:06:40 AM   #44
CSLM3Wannabi
my pleasure
Old Wed, May-22-2019, 12:11:01 PM   #45
Kenny167
Any updates on this? I'm curious of the outcome
Old Wed, May-22-2019, 12:59:57 PM   #46
alwaysbored786
The last week or so i've been trying to get a hold of Frank at TTFS, its pretty difficult to get him on the phone. Once I can get a hold of him, i'll give another update as to what he says.
Current Stable:
Discussing At my wits end, misfire issue, OBDII monitors incomplete... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
