Old Fri, May-10-2019, 04:16:01 PM   #1
nholmes
Track Junky
nholmes's Avatar
Question MOV'IT BBK Question(s)
Hey party people!
I was recently given an old MOV'IT BBK with 993TT/996 calipers and I'm having a hard time locating instructions regarding modifications to the knuckles for the radial brackets.
I know this kit is almost 15 years old and it might be a long shot, but would any of the sages in here have any memory or ideas regarding this before I just take out an angle grinder and start removing material?
I already emailed Steve at Ultimate Garage as well, since he was one of the original importers for this kit.
Thanks and happy driving!
-Noah
Check out my build!
Originally Posted by Nate047 View Post
Are you feeling loose in the rear end currently?
Old Fri, May-10-2019, 08:34:13 PM   #2
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Default Re: MOV'IT BBK Question(s)
I had this kit on my 328i but it came with E36 adapter brackets, but not to make them radially mounted. You sure you have the correct ones?
Jump to top M_Parallel is online now   Reply With Quote
Old Fri, May-10-2019, 09:13:13 PM   #3
frbz
Reputation: 0 frbz is on a distinguished road
at about 1 min into the video he goes over the parts he uses and where he got them from
Jump to top frbz is offline   Reply With Quote
Old Fri, May-10-2019, 10:49:30 PM   #4
nholmes
Track Junky
nholmes's Avatar
I don't have the creative radial mounts, I have the original ones from MOV'IT.
These guys:
The problem is that they don't line up against the knuckle perfectly, they're offset slightly due to the knuckle shape.
I've seen some of the other kits require modification, like this one for the rear on the E39(?):
Check out my build!
Old Sat, May-11-2019, 11:33:21 PM   #5
nholmes
Track Junky
nholmes's Avatar
Looks like the top hats for the rear will require removal of the ebrake assembly and grinding down the cable bracket.
Check out my build!
Discussing MOV'IT BBK Question(s) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
