Old Tue, May-07-2019, 10:55:40 AM   #11
Frost12850
Reputation: 0 Frost12850 is on a distinguished road
Default Re: What are these holes and why is transmission fluid leaking from them?
So I decided to do some further self diagnosing- although I am dropping it off at my mechanic today. I thought about whether or could be the gear selector seal, so having not driven the car in awhile, I decided to get into it and manually shift through some gears. Left it overnight and found this morning that a few drops had went into the cardboard on the floor. Is the selector seal the likely culprit?
Jump to top Frost12850 is offline   Reply With Quote
Old Tue, May-07-2019, 02:17:42 PM   #12
englishtom1596q
englishtom1596q's Avatar
No. Selector shaft seal will drop oil down the tail of the trans where the drive shaft connects. It’s coming from in the bell housing and since it’s ATF, that means trans fluid which means input shaft seal.
Old Tue, May-07-2019, 02:19:00 PM   #13
Frost12850
Originally Posted by englishtom1596q View Post
No. Selector shaft seal will drop oil down the tail of the trans where the drive shaft connects. Itís coming from in the bell housing and since itís ATF, that means trans fluid which means input shaft seal.
Ok- I appreciate your input. Thanks.
Discussing What are these holes and why is transmission fluid leaking from them? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
