Old Wed, Jan-23-2019, 12:04:46 PM   #681
Olza
Code monkey
Olza's Avatar
Reputation: 0 Olza is on a distinguished road
Belarus
Default Re: Comprehensive MSS50 DME information (Euro E36 M3 S50B32 321 PS)
Originally Posted by dafoxm3 View Post
Thanks M3AN!
so my Dyno chart attached https://imgur.com/a/ygjQ7ge
@Olza, yes i am looking for a XDF that has vanos parameters outlined and also timing so i can play around with the tune
Bert ///M3 already said you vanos offsets in calibration data.
Also, look at old emails between us. I sent you needed XDF with vanos info.
Jump to top Olza is offline   Reply With Quote
Old Fri, Jan-25-2019, 12:46:40 AM   #682
dafoxm3
Reputation: 0 dafoxm3 is on a distinguished road
Hi Olaz, thanks for replying.
Previous XDF was password locked and i could never use it
I dont know if Bert///M3 mentioned the hex locations of the calibration data , i will go back and look again
Jump to top dafoxm3 is offline   Reply With Quote
Old Tue, Feb-26-2019, 03:19:43 AM   #683
dafoxm3
So I have been working with the limited data i have, and revised all PT fuel maps.
interesting result, after the flash and clearing of adaptations, the LTFT changed from ~ -22% to -1.3% ( and on bank 1-3 + 0.8%) so i was very pleased.
the results remained like this for about 2 weeks, but have now slowly moved back to -12% (with no change to the tune)
could this be pointing to fault o2 Sensors ?
Old Tue, Mar-12-2019, 11:39:15 PM   #684
dafoxm3
So the saga (mystery) continues. I have now pulled about 20% fuel out of the Part throttle map. The current map is is overall about 1.7 (afr ratio) higher than original. however, i am still seeing LTFT adaptations of;
Bank 1 -17%
Bank 2 -12%
could this be the o2 sensors or something else ? TPS?
Old Mon, May-20-2019, 07:41:15 AM   #685
dafoxm3
Flash counter . .. is there anyway to reset this ? or bypass the limit ? i am on flash 59 so no more re flashing for me !!
Old Thu, Jun-13-2019, 12:18:39 PM   #686
jagga
Reputation: 0 jagga is on a distinguished road
United Kingdom
instead of remapping the old ecu on my m3 evo i bought this https://www.pnpecu.com/vems-s50b32-pnp-kit-7-p.asp
it uses a map sensor to detect load and more modern air temp sensor that reacts faster to changes in temp than the original. also controls double vanos.
also has a much larger resolution map than the stock ecu and comes with a basemap for a standard engine.
it uses the stock ecu socket so no messing with wiring you just fit the ecu, tee in the map sensor to the fuel pressure regulator vacuum line then calibrate the new wideband 02 sensor and tps and you can start and drive the car.
final tuning will be done on a dyno.
time has moved on and alpha n is too dated i should get much better drive-ability with the vems.
Jump to top jagga is offline   Reply With Quote
Old Thu, Jun-13-2019, 08:42:29 PM   #687
M3AN
321 fun...
M3AN's Avatar
Reputation: 0 M3AN is on a distinguished road
New Zealand
Keen to hear your feedback once it's in.
/// E36 M3 Coupe / Estoril Blue / Lotus White
/// S50B32 / 6MT / Slick Top / Alu Doors / Z3 Rack / Simota / Remus / Bilstein B6 / Eibach Pro+ / BBS RC / Goodyear F1 / Rally Road Bits / 3.62 CWP (TBI)
Jump to top M3AN is offline   Reply With Quote
Discussing Comprehensive MSS50 DME information (Euro E36 M3 S50B32 321 PS) in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
