Old Sun, Dec-14-2014, 05:13:43 AM   #1
androofoo
Buildjournal
androofoo's Avatar
Reputation: 0 androofoo is on a distinguished road
Default Beisan VANOS Rebuild at Lang Racing Development
My car started to idle very rough, run rich, and sometimes randomly went into limp mode while driving. It was diagnosed as a faulty VANOS on the exhaust side so I thought it was time to do the full VANOS rebuild using the Beisan Systems parts. I took it to Andrew at Lang Racing Development here in Irvine, CA. I took some photos of the rebuild. I get the car back tomorrow and I am happy to finally get this done! Back to the track soon hopefully!
More photos at http://thebuildjournal.com/shops/bei...4-lang-racing/
Valve cover open and VANOS unit out.
New oil pump disc with re-drilled holes.
Both my exhaust hub tabs were intact at 145k miles!
All intake sprocket sleeve bolts were intact and snug as well!
VANOS solenoid was bad.
New VANOS solenoid rebuilt by Beisan!
Anti-rattle kit installed.
Broken chain guide.
2003 BMW AW/Cinnamon E46 M3 6MT | B-Spec Tune
2018 Toyota Tacoma TRD Off-Road Cement/Leather
2012 BMW Sapphire Black/Black F30 328i | GIAC Stage 1 Tune (sold)
2007 Subaru Legacy GT Satin White Pearl/Leather 430 WHP (sold)
Follow this build on thebuildjournal.com
Jump to top androofoo is offline   Reply With Quote
Old Sun, Dec-14-2014, 05:52:15 AM   #2
DirtBag335
Reputation: 0 DirtBag335 is on a distinguished road
Default Re: Beisan VANOS Rebuild at Lang Racing Development
This makes me want to get mine done. I hope you got your front bumper problem resolved.
Jump to top DirtBag335 is offline   Reply With Quote
Old Sun, Dec-14-2014, 07:48:06 AM   #3
bjz
bjz's Avatar
Reputation: 0 bjz is on a distinguished road
Spain
Nice. Andrew is a good guy and work great.
Jump to top bjz is online now   Reply With Quote
Old Sun, Dec-14-2014, 07:51:38 AM   #4
Tinnit
Reputation: 0 Tinnit is on a distinguished road
Love the high quality pictures.
Does the rebuilt solenoid from Beisan differ from a stock replacement solenoid? Does it have any improvements to stave off future failures?
Jump to top Tinnit is offline   Reply With Quote
Old Sun, Dec-14-2014, 01:49:11 PM   #5
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
It is different, but I can't remember how. i think the stock one is prone to having the solder breaking or cracking which is addressed on the Beisan version. I am sure someone will chime in with better information than mine.
Mr. Wolfe
1994 Porsche 911 Factory Widebody
Old Sun, Dec-14-2014, 06:11:01 PM   #6
androofoo
Buildjournal
androofoo's Avatar
No it's still the same, but it's on there pretty good!
How Raj explains, there are a couple of issues with the solenoid pack.
Solder joints crack due to mechanical vibration or weak solder joints. Depending on how the rebuilt packs are soldered, it may strengthen the joint reducing risk of cracking so a well soldered connection should improve life.
Solenoid valve sticking failure is due to sludge buildup in the valve piston cylinders. To be honest, not sure what this is.
Solenoid sealing plate rings flatten and crack due to temperature overexposure allowing oil to leak through. The old Buna o-rings can withstand 212F, however the Beisan-supplied Viton o-rings withstand 400F. New o-rings should decrease the chances of oil seepage.
I would say the Beisan solenoid packs lessen the risk of future failures.
Old Sun, Dec-14-2014, 06:15:12 PM   #7
normcaldwell
Reputation: 0 normcaldwell has a spectacular aura about
Thanks for the post and pics.
For the broken plastic chain guide, I wonder where the broken-off plastic piece went.
Were you able to retrieve that piece?
Jump to top normcaldwell is offline   Reply With Quote
Old Sun, Dec-14-2014, 06:52:40 PM   #8
bimmerfan08
bimmerfan08's Avatar
Is the average DIYer able to re-solder the problematic joints in the solenoid pack? Doesn't sound difficult in concept but I'll let Raj chime in if he can.
Old Sun, Dec-14-2014, 06:56:59 PM   #9
Banang0
Few Dollars; Less Sense.
Banang0's Avatar
Reputation: 0 Banang0 is on a distinguished road
United Kingdom
Beisan is the best. Raj does a huge service for the E46 community and he is a pleasure to deal with - a natural teacher and a person of great patience for dealing with the DIY-challenged. BMW should thank him.
2002 M3, mildly enhanced
2005 M3 ZCP, much as it left the factory
2006 E86 M
2015 GT3
Jump to top Banang0 is offline   Reply With Quote
Old Sun, Dec-14-2014, 07:51:04 PM   #10
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
you need the correct solder station to make the work easier.
Jump to top deadlysyns is offline   Reply With Quote
beisan, exhaust hub, solenoid, vanos
Discussing Beisan VANOS Rebuild at Lang Racing Development in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
