Old Wed, Feb-21-2018, 05:02:05 AM   #11
erickrayos
Default Re: Vincebar
from his latest update on his thread he put up a new kit that he says there's no need to drop the rear subframe. too lazy to search it right now to quote it but its out there.
Old Wed, Feb-21-2018, 05:43:18 AM   #12
delvin
Water Champion
Reputation: 0 delvin is on a distinguished road
I'm guessing he means a complete drop, as in removal. As it stands now you only need to undo a couple bolts and lower it slightly to get the longer stuff in.
OP I have an epoxy bar kit I bought during the GB, PM me if you are interested
Jump to top delvin is offline   Reply With Quote
Old Wed, Feb-21-2018, 07:24:49 AM   #13
mrgizmo04
mrgizmo04's Avatar
To lower it a little is basically removing it because the front 2 bolts are double sided studs with one end screwing into the floor and the other end having a nut that holds the racp onto it. To get a longer bolt n, you need to lower the subframe about 5 inches to get the shorter ones out. I may be wrong, but that is my understanding.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Feb-21-2018, 01:21:32 PM   #14
bimmerfan08
bimmerfan08's Avatar
Has anyone personally installed a Vincebar? Every M3 owner with a Vincebar that I've talked to has used a shop for the install rather than do it themselves. Just trying to gauge how DIY-friendly the install is. Seems straightforward as I've already done plates on my M3.
Old Wed, Feb-21-2018, 01:28:18 PM   #15
mrgizmo04
mrgizmo04's Avatar
See in post 9, YouTube channel shoplife have done it in their own shop, so sort of diy. I think he actually has his shop somewhere in socal. Maybe you can reach out to him with questions.
'05 M3 6MT coupe
Old Wed, Feb-21-2018, 01:58:57 PM   #16
erickrayos
yeah he got his shop in alhambra or whatever its called, near LA, about 1.5hr-2hr drive from SD. He hasn't responded to my emails or PM's here and the other forum and I've sent them months ago.
Old Wed, Feb-21-2018, 02:00:41 PM   #17
chronos3333
Reputation: 0 chronos3333 is on a distinguished road
I did it myself Epoxy method. I did a thread about it on the forum
Jump to top chronos3333 is offline   Reply With Quote
Old Wed, Feb-21-2018, 02:04:27 PM   #18
mrgizmo04
mrgizmo04's Avatar
You mind linking here?
'05 M3 6MT coupe
Old Wed, Feb-21-2018, 02:17:32 PM   #19
chronos3333
Here it is: http://www.m3forum.net/m3forum/showthread.php?t=551640
The thing is I use fewer but bigger rivets and didn't used 3M epoxy. My car was one of the first if not the first "all" epoxy install (beside stopping&welding the little cracks). Holding well so far.
Old Wed, Feb-21-2018, 06:53:06 PM   #20
ebmw21
Reputation: 0 ebmw21 is on a distinguished road
I've done one complete install and starting on the second this week. if you are handy with a wrench you should have no problem, but i will say this it takes a lot longer then the usual subframe reinforcements to fit the bar and gusset cups. Take your time with it.
BBS LM | ST suspention | Bee-r Intake | AP V1 | Rouge Sec2 | CPI Rasp Terminator | Headers | CSL SMG Coding |
CSL Bumper | Beisan Vanos Rebuild |
Insta: @jstrattn
Vancouver BC area ECUWORX coding avalable.
Jump to top ebmw21 is offline   Reply With Quote
Discussing Vincebar in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
