Old Mon, Feb-19-2018, 02:38:11 AM   #51
kaiv
SoCal S54 specialist :P
kaiv's Avatar
Reputation: 0 kaiv is on a distinguished road
France
Default Re: Smg to 6mt??? Hurt or increase?
While we're on this topic:
Since I do so many, some naturally end up for sale. I get hit up from time to time by potential buyers who are a bit skeptical. Once i give them a clear picture and explanation of what goes on with a conversion they usually have no more concerns. The majority of people (or well at least E46 M enthusiasts/shoppers) seem to be open minded that way.
On the other hand I've also noticed once or twice some cars I've converted listed online by their seller with no disclosure of the trans conversion Makes me raise an eyebrow but apparently they sell just the same
E46 ///M325i Touring journal
Kaiv's SoCal Feedback! IG: limited.slip
Jump to top kaiv is offline   Reply With Quote
Old Mon, Feb-19-2018, 02:38:40 AM   #52
DoubleSidedTape
Reputation: 0 DoubleSidedTape is on a distinguished road
Originally Posted by Toasty View Post
Money aside, my issue with doing mods outside of the "usuals" (IE, coilovers, SSK kits, exhaust, exct) is that I can't help but wonder if all the time and effort required to do them right is worth it vs. just moving over to a different car altogether. In my own case, I often wonder if just buying an S2000 and figuring out a way around it's impracticality as a DD would be easier than modifying an E46 M3 to excel in ways it may never be able to do without doing a Singer-level rebuild of it.
I own both. My conclusion is that I can't live with the s2000 as an only car (in Seattle), and that it doesn't make sense to own two cars. So I'm selling the s2000 and will be trying to dial in my m3 to drive like the s2000 did.
Jump to top DoubleSidedTape is offline   Reply With Quote
Old Mon, Feb-19-2018, 02:45:12 AM   #53
Dave B
M3 collector
Dave B's Avatar
Reputation: 0 Dave B is on a distinguished road
Italy
That's just foolish. Your work is so well documented and photographed that that kind of disclosure can only add value to the sale. There'll still be the collector types that only want factory, but many many sane people in the used market appreciate thorough documentation of work, no matter how complex. (Imagine that...)
Jump to top Dave B is offline   Reply With Quote
Old Mon, Feb-19-2018, 03:00:22 AM   #54
kaiv
kaiv's Avatar
France
Smile Re: Smg to 6mt??? Hurt or increase?
From the feedback I've gotten thus far, I think you're right :-)
Old Mon, Feb-19-2018, 04:44:58 PM   #55
SeattleLSB
SeattleLSB's Avatar
Reputation: 0 SeattleLSB is on a distinguished road
Originally Posted by e46lsb View Post
From start to finish, I agree with Dave’s post.
Often I do wonder if kaiv ruined the value some for my car. But if he hadn’t switched it, I truly wouldn’t of bought it in the first place.
If it ever comes down to it, you can simply pick up the used parts again and revert it back.
Almost all of these M3's are going to be Sub 20K these days, are we really concerned about what a sub 20K car is worth these days?
Drive the car, enjoy it and use it to it's fullest. I'd be far more concerned with the subframe than a swapped car.
BTW, I love my DCT in my E90 M3! While I miss rowing the gears I think I've made the conversion to quicker, more automated transmissions in the future. It's defiantly better at the track than any manual.
2011 AW/BLK E90 M3>DCT
2003 LSB/BLK M3>SMG
2003 AW/BLK 330XI>AT>Winter Beater
Jump to top SeattleLSB is offline   Reply With Quote
Old Mon, Feb-19-2018, 04:46:35 PM   #56
e46lsb
e46lsb's Avatar
Reputation: 0 e46lsb is on a distinguished road
Every trace was replaced to eliminate the smg past. From correcting the instrument cluster to a new wheel. Cars never reverting back.
Individual- inside and out.
Jump to top e46lsb is offline   Reply With Quote
Old Mon, Feb-19-2018, 05:05:16 PM   #57
SeattleLSB
SeattleLSB's Avatar
You removed all the excess wiring for the SMG hood latches and swapped to manual hood latches even? That's a pretty committed Swap! I thought only Braymond was that OCD!
2003 LSB/BLK M3>SMG
Old Mon, Feb-19-2018, 05:07:17 PM   #58
e46lsb
e46lsb's Avatar
Maybe every trace was a bold statement. The swap was done by kaiv. Then I ascetically made changes to take away the visual signs of the smg.
Old Mon, Feb-19-2018, 05:39:01 PM   #59
How does the 6mt hood sensor wiring differ from the smg hood sensor wiring?
Old Mon, Feb-19-2018, 05:40:38 PM   #60
SeattleLSB
SeattleLSB's Avatar
SMG Hood Latches the lower ones under the radiator support are connected to the SMG harness to help determine wheter or not the hood is closed.
I'm assuming it's a magnetic or hall type switch.
Quick way to identify a real from converted car is looking down the hood latch hole with a flash light and seeing the switch. If you don't have access to a Vin decoder etc.
https://www.ecstuning.com/b-genuine-...k/51237893575/
2003 LSB/BLK M3>SMG
Discussing Smg to 6mt??? Hurt or increase? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
