Old Thu, Dec-15-2011, 06:51:05 PM   #11
Default Re: E36 M3 check engine light comes off when I let off gas...
I don't have an answer, but will add a comment. When the throttle closes on deceleration the injectors cut off to save fuel. This is determined by the TPS. Maybe a throttle cable or cruise control cable is tangled up under the TB. Typically if the throttle was lodged open, the idle would be so high the ECU could not adjust it down. Another possibility is some sort of vacuum leak under the high vacuum of deceleration, such as a split idle air valve hose that opens only under that condition. Ideally, I would scan with a sophisticated scan tool to check for other codes.
Old Thu, Dec-15-2011, 07:50:30 PM   #12
jayjaya29
Photographer
jayjaya29's Avatar
Originally Posted by ssyellow View Post
Thats what I was hoping to hear. Which cable exactly would I be adjusting in this picture?
Not sure, just follow the cables to where they originate. Adjust the one that goes into the firewall. There is a plastic, ribbed adjuster, just turn it until MOST of the slack in the line is taken up. Do not over tighten it.
Old Fri, Dec-16-2011, 02:21:41 AM   #13
fsmtnbiker
Reputation: 0 fsmtnbiker is on a distinguished road
Tightening the throttle cable will not keep the CEL from turning on.
You can test the TPS with a multimeter.
Chris
97 M3
Jump to top fsmtnbiker is offline   Reply With Quote
Old Fri, Dec-16-2011, 05:05:50 AM   #14
ssyellow
Reputation: 0 ssyellow is on a distinguished road
Thanks for the help everyone. Ill try the cable to see if that works then test the TPS with the multimeter tomorrow. It appears the code is only thrown after i accelerate hard 70%> throttle. After that it only comes on when I let off the gas. I'll report tomorrow what I find. Really appreciate the help everyone.
Jump to top ssyellow is offline   Reply With Quote
Old Fri, Dec-16-2011, 07:16:12 PM   #15
ssyellow
Did a quick test of my own. The car now has a hesitation on cold start and if I push the gas the RPMs drop first then go up. Unplugged the sensor and it runs perfect with no hesitation at all. Going to test it electronically for OHMs and see what values I get but I feel at this point its pretty conclusive its the TPS sensor itself.
Old Fri, Dec-16-2011, 08:22:49 PM   #16
white-hot
is lurking around the corner
white-hot's Avatar
Interesting. Mine has done that a few times when very cold, but I have never gotten any codes from it. I may look into that...
Old Tue, Feb-07-2012, 05:00:59 AM   #17
trackstar
Reputation: 0 trackstar is on a distinguished road
What was the verdict here? I am getting intermittent tps code (per peake), but no noticeable issues with idle or throttle response. Just wondering before I buy a new tps.
Jump to top trackstar is offline   Reply With Quote
Old Tue, Feb-07-2012, 04:19:56 PM   #18
DLite
Reputation: 0 DLite is on a distinguished road
Do this.
Jump to top DLite is offline   Reply With Quote
Discussing E36 M3 check engine light comes off when I let off gas... in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
