Old Mon, Jan-27-2020, 04:05:55 AM   #1
eacmen
Default Getting Access under Engine with BW Splitter Installed
sooo. Went to go do valve adjustment on our new track car. It still has the factory fan shroud and mech fan. Need to get access under the car to get the fan shroud off.
Also has the Bimmerworld CF front splitter. The BW splitter design is one piece splitter/lip that wraps up around the front of the bumper and it attaches with plastic rivets.
So it Seems like if we have to get under the car the whole bumper needs to come off. Can anyone else with the BW splitter give some advice on removal?
Of course the difficulty is compounded by the fact that there is brake ducting as well. The ducts are also riveted to the bumper.
Pics of various parts of the splitter and how its attached.
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Mon, Jan-27-2020, 02:01:20 PM   #2
Default Re: Getting Access under Engine with BW Splitter Installed
Looks like whoever installed it donít really plan it out too well.
Old Mon, Jan-27-2020, 04:22:51 PM   #3
DanAvoN7
Reputation: 0 DanAvoN7 is on a distinguished road
The splitter itself should be separate from the front airdam and canards which are riveted to the bumper. Once you detach both clusters of (3) bolts securing the splitter to the splitter standoffs, the (2) outer bolts securing the ends to the airdam, and the (2) rear brackets to the aluminum reinfrocement plate the splitter should then come down. Often times the low profile allen bolt heads under the car will get scraped/damaged so you made need to use a cutoff wheel to make a slot in the bolt head and use a flat head screw driver to remove them.
04 BMW M3 6spd - Alpine White/Black
Apex ARC-8 w/ Hankook Z214, Apex ARC-8 w/ BFGoodrich R1, MCS 3-way Coilovers, GC Race Camber Plates, PFC BBK, Turner Camber Arms, Turner Sway Bars, Turner Subframe bushings, Turner Solid Diff Bushings, Turner Solid RTAB, Turner Solid Control Arm bushings, Treehouse Racing FCAB, Reinforced Subframe, OS Giken LSD, Rogue Engineering Transmission Mounts, SGT Headers, SGT Section 1, AFE Stage 2 Intake, EPIC Tune, Dinan Exhaust, Bimmerworld Airdam/Splitter/Dive Planes, Bimmerworld V2 Wing, TC Design Roll Cage, Racetech RT4119, Scroth Profi 2 Harness
NORCAL Rod Bearing/Vanos/Valve Adjustment/Inspections Member Feedback
Jump to top DanAvoN7 is offline   Reply With Quote
Old Mon, Jan-27-2020, 04:25:23 PM   #4
eacmen
Originally Posted by DanAvoN7 View Post
The splitter itself should be separate from the front airdam which is riveted to the bumper. Once you detach both clusters of (3) bolts securing the splitter to the splitter standoffs, the (2) outer bolts securing the ends to the airdam, and the (2) rear brackets to the aluminum reinfrocement plate the splitter should then come down. Often times the low profile allen bolt heads under the car will get scraped/damaged so you made need to use a cutoff wheel to make a slot in the bolt head and use a flat head screw driver to remove them.
thank you! I was literally just arriving at this conclusion myself. At first glance it looked like the air dam/lip has adhesive on it so I thought it was all one piece. Going to try dropping it later on today.
Much appreciated!
Old Mon, Jan-27-2020, 08:45:07 PM   #5
eacmen
success! This is the best car community hands down.
Old Tue, Jan-28-2020, 02:26:26 PM   #6
Feffman
Grand Poobah
Feffman's Avatar
Reputation: 0 Feffman is on a distinguished road
Thanks Peter!
MVP Track Time
Jump to top Feffman is online now   Reply With Quote
Discussing Getting Access under Engine with BW Splitter Installed in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
