Old Tue, Jul-10-2018, 06:25:11 PM   #1
Pic18
Reputation: 0 Pic18 is on a distinguished road
Default Electric Fan mounting
So I searched a bit on the forum and couldn't find anything about using push through nylon mounts like below for mounting a fan directly to the Radiator. Is there a reason most seem not to use these?
For background I have Mishimoto fan attached using their aluminum shroud, but the fan is extremely close to the AC pulleys and belts and has come loose (from top mounting point) at least once and rubbed on the pulley/belt. I would rather not push nylon rods through the radiator, but I am worried that the current configuration will come loose again and destroy the fan and belt.
Jump to top Pic18 is offline   Reply With Quote
Old Tue, Jul-10-2018, 08:34:54 PM   #2
bigjae1976
Default Re: Electric Fan mounting
Iíve used them...they work fine.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Tue, Jul-10-2018, 11:36:42 PM   #3
Newswartz
Newswartz's Avatar
Reputation: 0 Newswartz is on a distinguished road
x2
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=215618&dateline=15216  66489
∑ Dinan ∑ Samco ∑ RPI ∑ Rogue ∑ UUC ∑
∑ iForged ∑ Mason ∑ Turner ∑ Rogue ∑ Brembo ∑
∑ AKG ∑ Redish ∑ Spal ∑ ST ∑ StatusGruppe ∑
∑ TurboToys ∑ Beisan ∑ Bilstein ∑ VinceBar ∑
Jump to top Newswartz is online now   Reply With Quote
Old Wed, Jul-11-2018, 08:09:29 PM   #4
Pic18
I appreciate the response, but just to clarify since "fine" to me means just ok, is there another set up you like better that still keeps the fan close to the radiator and farther away from the belts/pulleys?
Old Wed, Jul-11-2018, 08:34:08 PM   #5
bigjae1976
Thatís probably your best option. Itís kind of a pain if you need to remove the fan. And you have to buy more mounts.
Old Wed, Jul-11-2018, 08:51:51 PM   #6
Drewster
Drewster's Avatar
The other option is to get a sheet of aluminum from Amazon, and make your own bracket (the route I took)
Even then, it's still close to the belts, etc. ...but I haven't had issues
Old Thu, Jul-12-2018, 12:15:08 AM   #7
Metro81
Reputation: 0 Metro81 is on a distinguished road
Check out N15 Design
http://n15design.com/product/n15-des...v=7516fd43adaa
TTFS | CPI | RE | APEX | PFC | KW | GC | BimmerWorld | Hard Motorsports | Status Gruppe | n15DESIGN | RaceWerks
Jump to top Metro81 is offline   Reply With Quote
Old Thu, Jul-12-2018, 01:51:16 AM   #8
Kcalhoun27
Reputation: 0 Kcalhoun27 is on a distinguished road
Made my own out of aluminum. Works just fine, havent had any interference issues
Jump to top Kcalhoun27 is offline   Reply With Quote
Discussing Electric Fan mounting in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
