Old Mon, Jul-09-2018, 10:57:45 PM   #1
csnow
Reputation: 0 csnow is on a distinguished road
Default Z4 M Roadster - buying one with vanos issues
I am considering buying a 2006 Z4 M. The previous owner just finished a fairly major repair that included replacing the vanos and also the exhaust sprocket. Is this a red flag? Or is it a good thing that the vanos has been dealt with already? I know itís a somewhat common issue in these cars.
Thanks!
Jump to top csnow is offline   Reply With Quote
Old Tue, Jul-10-2018, 01:29:59 AM   #2
///NotEvnMyBDay
///NotEvnMyBDay's Avatar
Reputation: 0 ///NotEvnMyBDay is on a distinguished road
Default Re: Z4 M Roadster - buying one with vanos issues
Sounds like a plus to me. I would just find out if it was replaced with stock or aftermarket. Might sound weird but aftermarket for vanos parts is better than stock. Look up beisan and you can see how they pretty much have an upgraded part for most bmw vanos parts. Especially the S54.
2002 E46 M3 - CB on Imola
1987 635csi - Black on Natur
1987 635csi - Black on Lotusweiss
Jump to top ///NotEvnMyBDay is offline   Reply With Quote
Old Tue, Jul-10-2018, 01:49:07 AM   #3
lmtfi
lmtfi's Avatar
Make sure you see documentation on claimed major repairs.
Old Tue, Jul-10-2018, 02:26:14 AM   #4
Kcalhoun27
Reputation: 0 Kcalhoun27 is on a distinguished road
If they didnt replace, youd have to. As long as you can get a clear picture of what was done during the procedure, it sounds like its probably a win.
Jump to top Kcalhoun27 is offline   Reply With Quote
Old Tue, Jul-10-2018, 04:38:12 AM   #5
csnow
This is the parts and service notes from the invoice. Looks like quite a lot of work was done. My guess is oem parts but it was at an independent garage that specializes in euro cars.
Old Tue, Jul-10-2018, 04:48:45 PM   #6
Texaz3
Looks like they just replaced the entire VANOS unit. Nice, but not bulletproof. Might fail again. Still better than unknown unit.
Old Tue, Jul-10-2018, 10:21:18 PM   #7
white_335i
Reputation: 0 white_335i is on a distinguished road
where in the receipts do you see that the vanos unit is replaced? I see gasket, but not the unit.
03 M3 SMG, 13 RRS
Jump to top white_335i is online now   Reply With Quote
Old Tue, Jul-10-2018, 11:20:30 PM   #8
csnow
On the parts list the second item is a vanos. It was a couple thousand for that line item. On the notes page under replace gasket they talk about replacing the vanos and exhaust sprocket once they got in there because the broken exhaust sprocket pin had started wearing the vanos.
Old Wed, Jul-11-2018, 03:39:44 AM   #9
Lawrence1
BF.c alumnus
Reputation: 0 Lawrence1 is on a distinguished road
Huge plus
Jump to top Lawrence1 is offline   Reply With Quote
Old Wed, Jul-11-2018, 07:35:20 AM   #10
mrgizmo04
mrgizmo04's Avatar
"Fairly major repair"...why/how did it fail that it required everything to be replaced? I've seen these fail where chain tensioner busts, chain skipping on sprocket, hub teeth breaking, etc.
Great that it's all being repaired, but again, why? I'd ask for a compression or a leak down test.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Discussing Z4 M Roadster - buying one with vanos issues in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
