Old Sat, Jul-07-2018, 01:13:49 PM   #11
LightlyToasted
Reputation: 0 LightlyToasted is on a distinguished road
Default Re: Coolant Drain Plug Block Removal Troubles :
Another option, if you can't get the block drain bolt out (or worse, strip it), is to use a vacuum filler. Suck all of the old fluid out, and use the same tool to fill it back up. Amazon has lots of them, and YouTube has videos demonstrating their use. Easy and quick, with the added benefits of not having to disturb any hose fittings and being mess free.
Edit: I was mistaken - the vacuum fillers are for filling, not draining. The procedure I watched a mechanic do was:
  • remove the thermostat from the housing (thermostat would likely not be open and would impede flow)
  • reinstall the housing without the thermostat, leaving hose off
  • pressure flush the system with water draining out of the hose which was attached to the thermostat housing
  • pressure drain with shop air
  • reinstall the thermostat and hose
  • pull a vacuum and check for leaks
  • refill with a vacuum filler
Jump to top LightlyToasted is offline   Reply With Quote
Old Sat, Jul-07-2018, 03:34:40 PM   #12
cncmastr
M-Texture Alcantara
cncmastr's Avatar
Reputation: 0 cncmastr is on a distinguished road
I'm with the crowd that say's don't kill yourself over it. Use the temp sensor location to get as much out as you can, then just fill it with distilled, run the engine, then drain again. Then, fill with new.
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | TTFS | CSL Airbox w/Flap | Shrick 288/280 - 350whp 275wft-lbs
Collection of my DIY Guides here
Personal Blog
http://www.obsessedmotorsport.com/blog
Jump to top cncmastr is offline   Reply With Quote
Old Sat, Jul-07-2018, 04:02:06 PM   #13
Originally Posted by Exclusivs View Post
If refreshing entirely - why not get all old fluid out possible?
The "why not" largely comes down to it being a huge pain in the ass to access the block drain.
Personally I'd drain it from the radiator, turn on the ignition (not engine) to let the aux pump do its thing and push a little more fluid out, and then call it a day.
Old Sun, Jul-08-2018, 12:12:08 AM   #14
DanAvoN7
Reputation: 0 DanAvoN7 is on a distinguished road
For those of you saying to skip draining the block There is a lot of coolant in the block itself and simply draining the radiator does not constitute a "coolant flush".
To make it easier you can remove the vanos accumulator bolt and then move the accumulator a bit out of the way. This will give you more room to get a socket w/ extension on the drain plug bolt and then use a large ratchet to give you the leverage needed to break it free. It's a bit messy when you remove the drain plug as it will all gush out so have a large tub underneath to catch it. And don't forget to remove the old crush washer (can either stick to the block or bolt) and replace it with a new crush washer when reinstalling the drain plug.
04 BMW M3 6spd - Alpine White/Black
Apex ARC-8 w/ Hankook Z214, Apex ARC-8 w/ BFGoodrich R1, MCS 3-way Coilovers, GC Race Camber Plates, PFC BBK, Turner Camber Arms, Turner Sway Bars, Turner Subframe bushings, Turner Solid Diff Bushings, Turner Solid RTAB, Turner Solid Control Arm bushings, Treehouse Racing FCAB, Reinforced Subframe, OS Giken LSD, Rogue Engineering Transmission Mounts, SGT Headers, SGT Section 1, AFE Stage 2 Intake, EPIC Tune, Dinan Exhaust, Bimmerworld Airdam/Splitter/Dive Planes, Bimmerworld V2 Wing, TC Design Roll Cage, Racetech RT4119, Scroth Profi 2 Harness
NORCAL Rod Bearing/Vanos/Valve Adjustment/Inspections Member Feedback
Jump to top DanAvoN7 is offline   Reply With Quote
Old Sun, Jul-08-2018, 04:01:16 AM   #15
bigjae1976
Worst case, support the motor and pull off the VANOS pressure accumulator and bracket.
There's a 10mm pinch bolt that pinches the canister. Remove that, slide the canister up and out. 2 13mm bolts to remove the bracket. Should be easy to get to the drain plug.
The reason why you want to support the motor is the 2 13mm bolts also secure the engine bracket to the block.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Sun, Jul-08-2018, 06:54:52 AM   #16
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
Appreciate all suggestions! For me draining remainder from block was necessity. Knew amount of coolant in there, and the fill/reflushes as suggested didn't sit right with me either running through a new radiator.
This is JUST from block drain, and that doesn't count the extra that was on the floor. Lots of patience, take your time, and 110% don't skip!
Jump to top Exclusivs is offline   Reply With Quote
Old Sun, Jul-08-2018, 02:33:22 PM   #17
bigjae1976
I would recommend installing a banjo bolt with a stainless steel line and a plug. Makes life easier and much less messier.
Old Mon, Jul-09-2018, 04:44:09 PM   #18
TheGenius46M
TheGenius46M's Avatar
That's a good idea. Do you happen to know the bolt size (pitch, threading and length) so I can order one in advance? Any recommendations?
2003 E46 M3 TiAg/Cinnamon 6MT
Karbonius | MCS | Volk | Recaro | OMP | Hyperco | Ground Control | Besian | AKG | Schroth | Bimmerworld | Turner | PFC | CSF | SuperSprint | Radium Engineering |
Bay Area/ Nor Cal Coding and DME Tuning Specialist. PM for inquiries.
Old Mon, Jul-09-2018, 05:23:09 PM   #19
A line going where? Are you talking about oil or coolant?
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer/fog delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
Old Mon, Jul-09-2018, 07:12:33 PM   #20
mrgizmo04
mrgizmo04's Avatar
I think it can be short and act as a spout for next time you have to drain the block.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Discussing Coolant Drain Plug Block Removal Troubles : in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
