Old Sun, Sep-11-2011, 03:13:00 AM   #11
1024m3
1024m3
1024m3's Avatar
Reputation: 0 1024m3 is on a distinguished road
Default Re: Purge Control Valve? P0444? DIY?
Thanks!
My light came on again tonight so I have to do this soon. Who had the best deal and can I have the part number?
Thanks again
Dynavin V5
Full BSW
DPE R07s Silver rivetless
KW2
Jump to top 1024m3 is offline   Reply With Quote
Old Sun, Sep-11-2011, 03:41:07 AM   #12
Dan4hockey99
stancebro4lyfe
Dan4hockey99's Avatar
Reputation: 0 Dan4hockey99 is on a distinguished road
Ukraine
PN is 13907831770. Realoem.com says it's $82 but dealer told me $104. I have a business account with my dealer so I get a discount and only paid $77. I don't know about other vendors. Good luck man and report back in case anyone else needs help with this code.
1998 BMW M3 LS1 Swap
| Felony Form | 5.7L LS1 | Enkei RPF1 | Renown | Brembo | BC Racing Coilovers |
Jump to top Dan4hockey99 is offline   Reply With Quote
Old Sun, Sep-11-2011, 03:53:36 AM   #13
1024m3
1024m3
1024m3's Avatar
Is this the bad boy?
http://www.ecstuning.com/ES35630/
Dynavin V5
Full BSW
KW2
Old Sun, Sep-11-2011, 03:55:07 AM   #14
Dan4hockey99
stancebro4lyfe
Ukraine
Originally Posted by 1024m3 View Post
That's the one!
Old Mon, Sep-12-2011, 04:27:23 AM   #15
fergraz
fergraz's Avatar
Reputation: 0 fergraz is on a distinguished road
Puerto Rico
I replaced a year ago. Is very easy.
2002 SMG ///M3 Tiag/Gray leather All Stock with 3x,xxx Miles
Jump to top fergraz is offline   Reply With Quote
Old Thu, Sep-22-2011, 11:38:55 PM   #16
1024m3
1024m3
1024m3's Avatar
Excuse the Iphone photos ... I took some pics in case someone else has this issue. It literally only took 25 minutes start to finish.
It helps to unclip the wire and pull out the plastic fastener holding it to the bracket. Then you can almost pull the hold valve out 6 inches for better access to hoses. One of the hoses slip off and the other has a sort of push to release feature.
Very easy!
Dynavin V5
Full BSW
KW2
Old Wed, Jul-19-2017, 02:37:53 AM   #17
TommyBoySTL
Reputation: 0 TommyBoySTL is on a distinguished road
Hey guys,
I replaced mine this morning. Wasn't too bad. Took about half an hour total.
Once you remove the air intake, you can see it a few inches back. It wasn't impossible to get to, but it isn't right there, either. I couldn't see where it was until I used my phone's light to find it. Anyway, it's just hanging there on a flat hook. You can push it backwards to remove and then it is connected by 3 things: Electrical connection and two hoses.
The electrical connection is in the back and you'll want to pry the metal retainer clip up with a screwdriver in order to release it.
The lower hose is removable by pressing in the plastic "C" ring to expand the fastener, just as our boy Bullsh%tkorner demonstrated. The larger hose that is closest to you can be pulled off by rotating the purge control valve while you pull.
I tried to upload some pics and a video, but I couldn't, so here are the links to my Google Drive. I kept getting a fatal error from the forum's server. Hope the links work. Best of luck. This is definitely a job a novice can do with a little patience and a few simple tools.
https://drive.google.com/open?id=0B1...VBHbXJRZ0lyZ3M
https://drive.google.com/file/d/0B1u...ew?usp=sharing
https://drive.google.com/open?id=0B1...Uw1czV6NEdzb00
Last edited by TommyBoySTL; Wed, Jul-19-2017 at 02:40:46 AM. Reason: Picture links edit.
Jump to top TommyBoySTL is offline   Reply With Quote
Old Wed, Jul-11-2018, 12:56:30 PM   #18
MWilsonApex
Reputation: 0 MWilsonApex is on a distinguished road
Hey all,
I replaced mine yesterday and when I pried up on the metal retainer that holds the electrical connection it flew off and ricocheted around the engine bay and off into oblivion.
I pushed that connector back on as firmly as possible, but was wondering if that clip is really necessary or not. I can't see that connector coming loose, but wanted to check here and see if I needed to find a new clip or not.
Thanks!
Jump to top MWilsonApex is offline   Reply With Quote
Discussing Purge Control Valve? P0444? DIY? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
