Old Thu, Oct-01-2009, 01:07:03 PM   #11
BAV_M_PWR
BAV_M_PWR's Avatar
Reputation: 0 BAV_M_PWR has a reputation beyond reputeBAV_M_PWR has a reputation beyond reputeBAV_M_PWR has a reputation beyond repute
You could always wire them to a 12v switched power source...and then connect a switch to
turn them on/off whenever you want
2003 JET BLACK ///M3 SMG
Originally Posted by //Ali View Post
What's lesson #2, oh Lord of Ridiculous Posts
Jump to top BAV_M_PWR is offline   Reply With Quote
Old Thu, Oct-01-2009, 01:28:39 PM   #12
mredwin25
mredwin25's Avatar
Reputation: 0 mredwin25 is on a distinguished road
Nice write up. That's how I'm hooking mine up except that I'm gonna just tap into the wires in the connectors at the corner lights. Just run that same trigger wire all the way to the front, easy access, easy to do and you don't have to remove some many panels. I wouldn't wanna mess with those wires at the LCM specially knowing those are known to be a pain in the ass to get coded at the dealer if it needs replacement. That's just my opinion.
Jump to top mredwin25 is offline   Reply With Quote
Old Thu, Oct-01-2009, 02:09:37 PM   #13
madmaverick
Reputation: 0 madmaverick is on a distinguished road
Originally Posted by [BlackDiamond] View Post
OP, what kind of angel eyes do you have? I like the look of them in the video, but do you have photos? (sorry for the offtopic)
60 LED umnitza Angel eyes, I'll get some pics for you
Originally Posted by TurtleTech View Post
Yes! This does work great with the 60 LED umnitza Angel eyes. They look very aggressive and extremely bright. Best way to wire in my mind.
Agreed!
Originally Posted by CarbonM3NY View Post
Can you tell me where did you tap the aux wire for the interior light? Did you tap that on the dome light? if so, which wire?
thanks!
Remove the glove compartment, its about 7 screws and it drops down. Tap into the red wire running to the floor well light. there is a rubber grommit that goes into the engine bay. just poke a hole and run it through, I'll get some pics of that too and add it to my post tonight.
I thought about that too... just figured this way I wont have to worry about accidentally leaving them on, and if you are running the switch from the battery it would be twice the wiring. Also have to mount a switch somewhere.
From what I read this is not a good option, the turn signals in the front are 6v when on, and 12v when the turn signal flashes. So this causes the angel eyes to flash with the turn signals.
The wire I tapped into is actually the one going to the rear parking lights.
Jump to top madmaverick is offline   Reply With Quote
Old Thu, Oct-01-2009, 02:17:17 PM   #14
mredwin25
mredwin25's Avatar
Really I didn't know that, mmmm I'll have to go try it and see...Thanks
Old Fri, Oct-02-2009, 11:04:53 PM   #15
mredwin25
mredwin25's Avatar
Agreed!
Yes you are 100% right, I just tried it and yes they do flash with the corner lights, tomorrow I'll do it your way, thanks for the nice write up.
Old Fri, Oct-02-2009, 11:56:30 PM   #16
Alchemist753
2003.07 E46 M3
Reputation: 0 Alchemist753 is on a distinguished road
I installed Umnitza Chromium Predator over a year ago wired to the accessory line so they work pretty much as DRL plus stay on for a little after the shutting car down.
My car is SilverGrau, so I welcome the DRL function has it makes the car MUCH more visible in daytime. It also helps they really really look great even in full sun.
I was originally a little concerned about battery drain/wear on the angel eyes/heat inside the headlight panel, but now I would wire my next ones exactly the same way. If you have LED based eyes, those concerns *should* be significantly reduced IMO.
I followed this DIY: hxxp://www.fastm.com/m3/angeleyes_chromium.html
Good luck with your install.
Jump to top Alchemist753 is offline   Reply With Quote
Old Wed, Oct-14-2009, 08:42:34 PM   #17
cone_killer
Reputation: 0 cone_killer is on a distinguished road
Thanks for the write up! I wired mine up last night, and it works great.
I had mine wired like the instructions here before:
http://www.fastm.com/m3/angeleyes_chromium.html
Which works, but everytime the angel eyes turn off, ECU box makes a zapping noise which I was not comfortable with. It didn't sound good, and it sounds almost like a short. Anyone else notice the same thing when wiring to the accessory wire?
Jump to top cone_killer is offline   Reply With Quote
Old Sun, Sep-07-2014, 04:42:59 AM   #18
Charbel_hw
Reputation: 0 Charbel_hw is on a distinguished road
Default Re: here's how to wire angel eyes to parking lights
can i know how did you connect to the parking light and to the cabin light to fade in and out i did this using same wire and it worked if the parking light is on
if it happens that they are on and i lock the car it doesn't turn off the cabin light so i had to disconnect the wire connected to the cabin wire
what do u mean by aux ??
can anyone help me with that please
Jump to top Charbel_hw is offline   Reply With Quote
Old Tue, Jul-10-2018, 07:58:57 PM   #19
MFan
MFan's Avatar
Reputation: 0 MFan is on a distinguished road
Just used this for an install works great! 2003 with LED rears. Thanks
2003 Mystic Blue, Grey Leather Ordered 2/7/03, born 3/20/03, Delivered 5/9/03 - Premium package, SMG, Nav, 19" alloys, bi-xenon's, Harmon/Kardon, Width adjustable seats, PDC, Cold weather package
Jump to top MFan is offline   Reply With Quote
angel, eyes, lights, parking, wire
Discussing here's how to wire angel eyes to parking lights in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
