Old Mon, Nov-15-2010, 10:22:37 PM   #1
gb007
gb007's Avatar
Reputation: 0 gb007 is on a distinguished road
Default 2008+ e9X M3s DSC question
Guys,
Quick question. When you press DCS on the car the light on the dash lights up yellow/amber. If you continue to press the button, does it light up RED? Are there two stages where it lights up or just one.
I thought there were two stages of DSC, but now the dealership is telling me there is only one.
Am I confusing this?
Jump to top gb007 is offline   Reply With Quote
Old Tue, Nov-16-2010, 01:12:08 AM   #2
elh0102
Reputation: 0 elh0102 has disabled reputation
Only one setting with the DSC switch. If you have the I-Drive option, I understand the M Dynamic mode is a less intrusive DSC setting. I have no options except DCT and comp package, so DSC is either on or off for me. I suppose the mid-range setting would have some advantage for some owners. But the car is so forgiving in handling dynamics, I really don't think many experienced drivers would want to use any DSC setting on track, and on the road it doesn't much matter anyway.
Jump to top elh0102 is offline   Reply With Quote
Old Thu, Nov-18-2010, 06:08:24 PM   #3
Them3guy90
Reputation: 0 Them3guy90 is on a distinguished road
Mine does the same
Jump to top Them3guy90 is offline   Reply With Quote
Old Mon, Nov-22-2010, 03:37:26 PM   #4
Double_J
Reputation: 0 Double_J is on a distinguished road
Only on or off unless you have M mode via iDrive.
Even with the M mode DSC setting, you can't select it via the console DSC button. You need to define your M mode settings in iDrive and then access them via the M button on the steering wheel.
Jump to top Double_J is offline   Reply With Quote
2008, dsc, e9x, m3s, question
Discussing 2008+ e9X M3s DSC question in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
