Old Sun, Nov-10-2019, 09:42:26 PM   #1
Carbuilder723
Reputation: 0 Carbuilder723 is on a distinguished road
Default E46 M3 differential Input Flange
Hey all,
I need some help from someone that has an M3 differential sitting around.
I need some dimensions of the input flange features. I have attached a picture to try to illustrate what I'm looking for.
Basically I need:
diameter at top of the taper (A)
diameter at the bottom of the taper (B)
total depth of taper (C)
depth of lip used to locate the grease seal (D)
Any help is appreciated!
Thanks!
Jump to top Carbuilder723 is offline   Reply With Quote
Old Tue, Nov-12-2019, 06:31:19 PM   #2
Carbuilder723
Default Re: E46 M3 differential Input Flange
Bump... Anyone??
Sent from my Pixel 2 XL using Tapatalk
Discussing E46 M3 differential Input Flange in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
