Old Mon, Nov-11-2019, 09:17:29 PM   #11
Fresh1179
Fresh1179's Avatar
Reputation: 0 Fresh1179 is on a distinguished road
Default Re: VANOS Rebuild Help—Not Enough Timing Chain Slack
Originally Posted by Whitehawk8 View Post
Holy mother of high quality. Those photos dont even come close to fitting on my 13 inch laptop screen.
Can you still not fit both sprockets?
perhaps there's a portion of chain dangling underneath the crank?
Let me check real quick. I don’t think so. I’ve pulled and rattled pretty well by now. One moment.
Enjoy Every Sandwich-Warren Zevon
Jump to top Fresh1179 is offline   Reply With Quote
Old Mon, Nov-11-2019, 09:46:11 PM   #12
Fresh1179
Fresh1179's Avatar
Default VANOS Rebuild Help—Not Enough Timing Chain Slack
Here are some more for you. With endoscope so they are pretty terrible quality. There appears to be some chain leading into the oilpan? Bottom is right side of crank. Is that red thing normal or am I seeing something....
Edit. Even if that portion of chain below the sprocket is not supposed to be there how the hell do I dislodge it.
Old Mon, Nov-11-2019, 10:03:18 PM   #13
Fresh1179
Fresh1179's Avatar
Hmm. Should it be laying across the TOP of the crank like that? Doesn’t make sense in the REAL OEM photos but I don’t know.
Old Mon, Nov-11-2019, 10:10:39 PM   #14
Fresh1179
Fresh1179's Avatar
I don’t see why it would be sitting on top but I have been wrong many many times before.
Old Mon, Nov-11-2019, 11:41:05 PM   #15
Fresh1179
Fresh1179's Avatar
So it’s not sitting on top. Sides are in grooves. Cannot see any loose chain underneath. This is the tightness WITHOUT the upper chain guide or chain tensioner installed. Tried many times like this. No dice. I cannot see directly under the crank but I don’t see anything dropping in the reflections. I’m baffled.
Old Tue, Nov-12-2019, 12:01:05 AM   #16
Fresh1179
Fresh1179's Avatar
I don’t know. Maybe I’ll try again but it’s been about this way and it’s just impossible to get it on with upper chain guide.
Old Tue, Nov-12-2019, 12:19:54 AM   #17
ThunderMoose
I usually fit the sprockets inside the chain and then slide them onto cams. Did you try it that way? You will not be able to put the sprockets on first and slide the chain on afterwards.
#67 2019 NASA National TT3 Champion; 2017 NASA TX TT3 Champion
FLMS Half Cage, RaceTech 4009HR drivers seat, Schroth 6-Pt Harness, E.S.S. Fire System, AIM SOLO DL with ECU Harness, SmartyCam, Angle Aluminum with VAC dead pedal, Sparco Steering Wheel on MOMO hub, MCS 2W NR, Hyperco 700F 800R springs, Hotchkis Front and Rear Sway bars, Vorshlag Camber Plates, Turner ARCA, AJ Hartman Front Splitter, BW V2 Wing, BW CF Rear Diffuser, APEX ARC-8 wheels, Brembo BBK Front, Carbon Fiber Roof, CF Headlight Blanks, Door Windows and Cards Delete, TMS rear and front subframe reinforcement, Zionsville Competition Cooler, BW Oil Cooler, Oil Diverter Valve, Motorsports Thermostat, Evolve CF Intake, Epic Stepped Headers, Turner Pulleys, BW 3.5" Race Exhaust, EPIC Alpha N Tune, Beisan Oil Disk and Vanos Seals, ZF 5MT, CAE Ultra Shifter
Old Tue, Nov-12-2019, 12:55:27 AM   #18
Fresh1179
Fresh1179's Avatar
I finally got it. A rogue chain link was snagged underneath cam. Used endoscope and coat hanger to dislodge it. My hands are bloodied and I spent 10 hours on one step but I’m alive. Thanks for the tips man. Sometimes you just need that moral support to keep going. Probably saved me 1000. But my chain tensioner broke so this continues to go well.
Old Tue, Nov-12-2019, 12:58:30 AM   #19
icecream
Registered Apples
icecream's Avatar
Lol. Glad you got it figured out though.
Jump to top icecream is online now   Reply With Quote
Discussing VANOS Rebuild Help—Not Enough Timing Chain Slack in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
