Old Fri, Nov-12-2010, 08:58:24 PM   #1
jmiahm3
Reputation: 0 jmiahm3 is on a distinguished road
Default Passenger seat not adjusting at all..what gives
Hey dudes, last week my passenger seat died. It does not move at all. I checked the fuse and its ok, what do you think is problem? The seat is also stuck all the way forward! Please help..
Jump to top jmiahm3 is offline   Reply With Quote
Old Sun, Nov-14-2010, 12:18:31 AM   #2
jmiahm3
anyone?
Old Mon, Nov-15-2010, 10:29:36 PM   #3
jmiahm3
Old Mon, Nov-15-2010, 11:02:37 PM   #4
bo///Man
bo///Man's Avatar
Reputation: 0 bo///Man is on a distinguished road
Check the connections under the seat..I had the same thing happen a few years ago and it was just a wire that had gotten disconnected.
Jump to top bo///Man is offline   Reply With Quote
Old Tue, Nov-16-2010, 02:57:12 AM   #5
jmiahm3
Do I know what connections I'm looking for? The heating elements in the seat still work so it's just the forward/backwards/tilt function. And also the seat is stuck all the way forward so it's hard to manipulate under there..any recommendations? TIA
Old Tue, Nov-16-2010, 03:03:55 AM   #6
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
look for a yellow box. the back side of that box connects to all the motor in the seat. the side of the box has a black square tab. separate that black tab from the yellow box and it will remove the harness. try re-seating the harness. also check for loose plug in back of the harness.
Tischer aka GetBmwParts
Old Tue, Nov-16-2010, 04:45:06 PM   #7
jmiahm3
will try this today..thanks
Old Thu, Nov-18-2010, 11:56:18 PM   #8
jmiahm3
turns out it wasn't the yellow box connections, all i got from that was a passenger seat belt light. It does look like I can get the seat out now if I do lift it up for "rear passenger entry". But then what? Am I looking to replace motors? And isn't it a big coincidence that both the tilt and forward/backward function went out at the same time?? Thanks again guys!!
Old Fri, Nov-19-2010, 02:42:04 AM   #9
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
it could be the control module on the side of the seat.
have you checked your fuses?
Jump to top deadlysyns is offline   Reply With Quote
Old Fri, Nov-19-2010, 08:49:53 PM   #10
jmiahm3
Ya I checked the "passenger seat fuse" (just one), is there more than 1 I should be checking? and how do I check the control module?
adjusting, allwhat, passenger, seat
Discussing Passenger seat not adjusting at all..what gives in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
