Old Fri, Apr-22-2016, 06:04:20 PM   #11
scansp7
Reputation: 0 scansp7 is on a distinguished road
Default Re: Power to Manual Seat Conversion
Any success with this? I also feel that I am sitting higher in the power seats than the manual...
Jump to top scansp7 is offline   Reply With Quote
Old Sun, Apr-24-2016, 10:44:41 PM   #12
01M3Fan
01M3Fan's Avatar
Reputation: 0 01M3Fan is on a distinguished road
I'm interested to hear status too
My build journal and mod list:
http://www.m3forum.net/m3forum/showthread.php?t=542798
Jump to top 01M3Fan is offline   Reply With Quote
Old Wed, Apr-27-2016, 08:05:02 PM   #13
Kirra
Reputation: 0 Kirra is on a distinguished road
Doing a cross-reference on realoem, the seat frames (cushion and back) are common for all seat variants. In other words, an M3 manual seat frame is the same as a base E46 manual seat frame. I see the easiest way to make the swap is to buy any manual seat and swap your foam and upholstery over.
Alternatively, the opposite swap has been done by swapping the cushion frame and misc parts (back frame is the same for manual and power). I'm guessing it would be more difficult and just as expensive to find only a cushion frame, rather than a complete seat... and a complete seat is an easier swap.
A junkyard seat should run you under $100, or here's a pair of manual frames for $370:
http://www.ebay.com/itm/2x-BMW-E46-L...tVPUMo&vxp=mtr
Jump to top Kirra is offline   Reply With Quote
Old Mon, Apr-03-2017, 12:18:44 PM   #14
Mr._T-Rex
Mr._T-Rex's Avatar
Reputation: 0 Mr._T-Rex is on a distinguished road
Netherlands
hmm, interesting! I will look into this to try and gain some headroom
M3 Competition - Interlagos on Dove - Journal
Jump to top Mr._T-Rex is offline   Reply With Quote
Old Mon, Apr-03-2017, 12:57:38 PM   #15
I believe the sliders could be swapped reasonably easily.
That said, I don't think that'll lower your seat at all (as in, not a single mm)-- the sliders mount to both the floor and the seats at the exact same location. I suspect the ~.75" of additional height (of the power seat vs the manual seat) is the rest of the power mechanisms under the seat.
If you don't go full manual, I doubt you'll get lower at all. In fact. I suspect you could get a fully manual seat, swap the power slider on, and not be any higher, either.
In short, I don't think a slider swap is going to help you at all. I'm also not sure how you'd actuate the slider on a power seat, since the slider release handle is built into the side of the manual seats...
conversion, manual, power, seat
Discussing Power to Manual Seat Conversion in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
