Old Tue, Oct-07-2008, 06:20:29 PM   #1
Timsta
Representing the 604 / 250
Timsta's Avatar
Reputation: 0 Timsta is on a distinguished road
Default help! Passenger Seat Lever Broken - how to replace?
Does anyone know how to replace the Driver/Passenger Seat lever? The lever allows u to roll your seat forward so passengers can climb into the back? my passenger side lever was broken, i got a replacement but not sure how to replace it. I've looked around without much luck for instructions
Thanks in advance
Tim
Current: BMW E63 M6
Officially Retired and Parted Out 2006 E46 M3 CB
Jump to top Timsta is offline   Reply With Quote
Old Sun, Oct-19-2008, 10:10:32 PM   #2
tomygunz7
Reputation: 0 tomygunz7 is on a distinguished road
Hey Timsta you ever figure out how to do this?? Im in the same boat lol
Jump to top tomygunz7 is offline   Reply With Quote
Old Sun, Oct-19-2008, 10:39:26 PM   #3
j-dog
Jdog
j-dog's Avatar
Reputation: 0 j-dog is on a distinguished road
If you can figure it out, do it yourself. Mine was under warranty so I had the dealer do it. It took BMW 2 F'ing weeks to get the part to my dealer, at least that is their story. Then it took several days for them to get to it.
06 ZCP. Jet Black. 6MT swap.
Jump to top j-dog is offline   Reply With Quote
Old Mon, Oct-20-2008, 03:29:45 PM   #4
Timsta
Timsta's Avatar
it takes 5 minutes to do. take a pair of pliers. grab hold of the broken piece. twist counter clockwise. pull. the broken piece comes out.
then. take the new part. stick into place til u hear a click. then u set!
took me about 3 minutes in total and this includes getting the little black cover off
Current: BMW E63 M6
Old Fri, Oct-24-2008, 10:13:13 PM   #5
tomygunz7
when I try to push the black plastic piece onto the metal lever it does not go in
Old Thu, Oct-09-2014, 03:03:02 PM   #6
crazy32184
crazy32184's Avatar
Reputation: 0 crazy32184 is on a distinguished road
Default Re: help! Passenger Seat Lever Broken - how to replace?
I know this is an old thread, but the lever on my drivers side just broke off.
Do you by chance have a picture or better explanation? It sounds like i dont have to take the cover on the back of the seat off in order to fix it...is that correct? Is it really just as easy as fixing it with the full seat intact?
Thanks!
Jump to top crazy32184 is offline   Reply With Quote
Old Thu, Oct-09-2014, 06:37:25 PM   #7
aspa
Reputation: 0 aspa is on a distinguished road
Hmm. I'll try to explain it with words.
realoem parts page for reference :
http://www.realoem.com/bmw/showparts...=52&fg=10&hl=9
The plastic handle (#4) is slipped onto a metal bar in the seats.
There's a plastic trim around the handle (#7) that you can just pop off with a plastic pry bar if you want to be able to see what's happening better.
The plastic handle is held on the metal bar with some plastic spring prongs. The twist-off method will basically just bend the prongs and get it to release. You can also get some small screw-drivers in there to release the prongs and then it just pulls off.
The replacement piece just pops in. (PN 52107064869 or 52107064870)
Jump to top aspa is offline   Reply With Quote
Old Thu, Oct-30-2014, 03:45:21 PM   #8
MikeR25
Reputation: 0 MikeR25 is on a distinguished road
So just to be sure I don't order the wrong part, could you please specify which part # corresponds to the driver's and passenger's seat? I'm in the US, and my driver side pull tore off, just want to make sure I order the right part. I wasn't sure if outer left or outer right meant facing the seat or when sitting in the seat. I'm probably over-thinking it..
Thanks!
Jump to top MikeR25 is offline   Reply With Quote
Old Thu, Oct-30-2014, 11:49:28 PM   #9
Pnick
Pnick's Avatar
Thanks!
left side 52107064869
Old Sat, Nov-01-2014, 02:18:11 AM   #10
crazy32184
crazy32184's Avatar
http://www.ecstuning.com/ES137933/
broken, lever, passenger, replace, seat
Help with broken passenger seat Fyaman E46 M3 (2001-2006) 0 Tue, Feb-12-2008 07:44:01 PM
Passenger seat tilt broken Fyaman E46 M3 (2001-2006) 0 Tue, Jan-29-2008 07:08:37 AM
Broken slider and broken passenger seat...bumper got rear ended kev1031 E46 M3 (2001-2006) 0 Thu, Jul-27-2006 10:50:01 PM
Passenger Seat "Lever" stopped working? Speedi E46 M3 (2001-2006) 1 Sat, Jan-15-2005 10:08:48 PM
2-Door seat back release lever broken BigPond3 E36 M3 (1992-1999) 2 Wed, Jan-05-2005 02:42:51 AM
Discussing help! Passenger Seat Lever Broken - how to replace? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
