Old Mon, Oct-08-2018, 10:59:44 PM   #11
nwGTS
Reputation: 0 nwGTS is on a distinguished road
Default Replace the wiper cowling
I was supposed to be at the track with my 911 today but thunderstorms around Chi said otherwise. So, I stayed productive and spent the time on the M3.
The current cowling was cracked and faded. It had to go along with the adjacent cowling plastics.
Here's what I was dealing with:
My first move was to pop off the wipers and rid the car of these ancient plastics.
I should not have been surprised but here's what was underneath:
Simple Green, detailer's spray, microfibers and brushes to the rescue.
I first thought the rubber drain tubes from the cabin air box were black (see above for yourself). After I hit them with some 303 they started to turn white. So I pulled them and sure enough the are a light gray. Poor car. This thing had dirt everywhere. I ended up pulling the cabin air box and cleaning all ducting leading into the cabin too.
All reassembled and ready to go:
Job done!
2003 E46 M3 Cpe Imola/Black 6MT
2012 997.2 GTS Black/Black 6MT/LSD/Aero
Jump to top nwGTS is online now   Reply With Quote
Old Thu, Oct-11-2018, 03:40:04 AM   #12
nwGTS
Default Center stack refresh update
Paint and clearcoat are cured and the center stack is back in the car. I still need to clean the radio, but that's far down the list yet.
After painting.
After Clear coat and reassembly with a before and after:
Back in the car:
Job done!
Old Thu, Oct-11-2018, 05:07:12 AM   #13
Texaz3
Default Re: Restoration Journal - Imola 6MT Cpe
Looks good. I have replaced all on mine, but in retrospect, should have probably done the same, and saved some coin. Oh well, there is ALWAYS next time. Especially with freaking "soft touch" crap on these.
Which paint/clear did you use? Looks proper semi-flat.
Old Thu, Oct-11-2018, 04:50:20 PM   #14
nwGTS
Totally get the 'nothing is better than OEM' mentality. I promised myself (and the Mrs.) I'd keep a certain budget on this car with an open checkbook on the 911. So far I'm under it. If this were the only ride and I could see a return on all OEM parts then I'd do that. Especially when most of these individual parts are all well under a hundred bucks each. Hard to justify the math when you need to refurb/replace dozens and dozens of parts though.
To your question, sticking with SEM trim black is probably all you need here. That stuff is tough and I'm using it all over the exterior and interior black trim on the car.
http://a.co/d/fdugxBh
Clear I used is Krylon Satin:
http://a.co/d/0PTKQGx
Unlike paint you really want to avoid more than one coat of premixed clear if possible. Two MAX. Otherwise you'll get a hazy cloudy finish on top as satin dries on top of satin. Same goes for matte. Less of a problem for semi-gloss and gloss.
2k clear is a different ballgame and was overkill for a small application like this.
Old Fri, Oct-12-2018, 03:54:14 AM   #15
nwGTS
Default C Pillar Refurbish
I'm basically moving back to front. C pillars first before I put the interior back together then B then A.
Just refurbished the C pillars with factory fabric and 3M 90 spray adhesive.
What's old...
...is new again.
Old Fri, Oct-12-2018, 07:56:41 AM   #16
L0ADED
L0ADED's Avatar
Default Re: C Pillar Refurbish
Pillars came out great. Do you think the 3M 77 would hold up as well as the 90 and did it stain the fabric on the outside?
What's old...
...is new again.
Old Fri, Oct-12-2018, 01:16:54 PM   #17
zippity
Reputation: 0 zippity is on a distinguished road
I wanted to do this to mine, but all of my connecting tabs are broken.
Jump to top zippity is online now   Reply With Quote
Old Fri, Oct-12-2018, 03:15:13 PM   #18
Steve M3
Great work so far, I am really enjoying this thread. In for more updates!
Jump to top Steve M3 is online now   Reply With Quote
Old Fri, Oct-12-2018, 04:43:43 PM   #19
nwGTS
I’m not familiar with 77. 90 is the go to for interior guys I know so I’ve gone on their reco to only use 90. And no staining at all. 90 sprains on like a gel. Once it's tacked up after 90 seconds or so it isn't going through the fabric.
Old Fri, Oct-12-2018, 10:15:36 PM   #20
nwGTS
Everything on the car will stay OEM and original except I needed a little more induction noise while I drove it. So this morning I did one thing for myself and added an aFe Stage 2 intake I picked up from a local enthusiast. Easy swap back when needed and sounds great while driving.
Discussing Restoration Journal - Imola 6MT Cpe in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
