Old Thu, May-31-2018, 09:14:31 PM   #11
jixer77
Reputation: 0 jixer77 is on a distinguished road
Default Re: Jixer77 06 Jet Black ZCP
Update 05/31/2018
Tires were getting worn out in the front due to heavy negative camber so I switched the old Continental Extreme Contacts and wrapped them with some Michelin Pilot Sport 4s. What A Difference! Not as easy to throw the back end out as it was with the Continentals.
I was recommended to go to Dynasty Auto here in Orlando. Bill, the tech, who took care of the alignment was great. He asked me good questions and cared about my preferences in regards to set up.
IMG_5167
IMG_5290
IMG_5286
IMG_5304
IMG_5288
Rainy Day
Jump to top jixer77 is offline   Reply With Quote
Old Thu, May-31-2018, 11:13:42 PM   #12
Looks like you've a great canvas to start with, good stuff.
_
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" + 200 cell HFC OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer delete CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing Mason clutch pedal + brass bushing TMS black pedals delrin brake pedal bushing
Old Wed, Jun-06-2018, 01:10:08 AM   #13
jixer77
Update* 06/01/2018
This actually happened a couple weeks ago but just now got around to posting it.
I noticed the front left rotor was hard to rotate when I was changing out my end link so I decided to clean out the pins and lube everything up with Syl-Glyde Brake Lube and I also noticed that there was major rust on the piston.
IMG_5235
IMG_5234
That ultimately didn't work so I decided to buy a rebuilt caliper from Centric for $139 minus the $75 core charge since I didn't want to spend the $300 on a BMW caliper. I eventually want to upgrade the brakes anyway so I figured I give it a shot for now. So far I have not had any complaints about it and it works.
I ended up walking into my garage to a big puddle of washer fluid...My windshield washer pump was leaking from the pump so I ended up replacing it with a Continental VDO washer pump for $35 and an OEM grommet for $5. Easy Fix thanks to this forum!
IMG_5281
IMG_5325
Capture
Don't ever buy this washer pump from URO Parts as it is crap. I ended up returning it and buying the VDO from Pelican Parts.
IMG_5331
IMG_5332
I also had a chance to replace my old reflectors since one of them was cracked and I just didn't like them. I bought these from Turner and they turned out pretty nice. **Pictures to come on the finished product**
Old Wed, Jun-06-2018, 01:13:13 AM   #14
jixer77
Fill up pic for shits and gigs.
IMG_5239
Old Thu, Jul-19-2018, 09:14:55 PM   #15
jixer77
Update 7/19/18
Parts came in today! Changing the Air Filter and Cabin Filter. Also got the ECS Magnetic Diff Drain and Fill Plugs.
IMG_5672
Old Thu, Aug-30-2018, 11:09:07 PM   #16
jixer77
Update 08/30/2018
New Floor Mats make all the difference.
IMG_5800
The old one just for reference. It was horrible driving with the mat rising up to the pedals.
IMG_5801
Old Fri, Aug-31-2018, 07:15:49 PM   #17
JClopes
Registered Loser
JClopes's Avatar
Reputation: 0 JClopes is on a distinguished road
Originally Posted by jixer77 View Post
Corrosion under cracking powder coat? Unlikely the solid bar would crack especially horizontal.
Great car none-the-less. Clean asf
///M Power
Jump to top JClopes is offline   Reply With Quote
Old Wed, Sep-05-2018, 09:19:12 PM   #18
jixer77
maybe but all good now. This car wil never see snow in FL. lol
Thanks bro!
Old Wed, Sep-05-2018, 09:25:22 PM   #19
jixer77
Update 9/1***
Replaced tranny fluid at 107,585 with SyncroMax.
IMG_5823
I dont know if I should be concerned about how dirty it was under there but I did degreased and cleaned it up a bit after I was done, sorry no picture when I was done lol.
IMG_5859
Old Thu, Sep-06-2018, 12:26:23 AM   #20
Kwakjoe
Kwakjoe's Avatar
Update 9/1***
IMG_5823
IMG_5859
I heard some mixed reviews about royal purple; what made you go with them?
Discussing Jixer77 06 Jet Black ZCP in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
