Old Sat, Jan-11-2020, 07:49:33 PM   #71
eacmen
Default Re: XDFproject BDMblock remake??
Originally Posted by tap View Post
Hey all!!! Wow sorry I had no idea you were all here working on this.
I can provide the Gerbers, etc if someone wants to take over building the existing BDMs for folks. It's about 2 hours to solder up a few at a time. The software as well if someone really wants to improve things.
I just frankly don't have the time anymore. I wish I did!!
I was working on a PC GUI that used USB HID to transfer files and flash directly from a RAM buffer, but the KL25 is pretty limited on RAM. Didn't really get too far with it. I really wanted the ability to command line call the flash from TunerPro for the data only so you could do fast data flashes while on the Dyno without the download step. It would definitely work using existing HW design I just got a new job and slammed with work lol.
If I gave someone the Gerbers would they order some and solder them up for people? Other than that it is programming the boards and doing a test flash and read to make sure it is functional.
Thoughts?
Welcome back tap! I have been working on the software side and have one of the boards that NZ_M3 made. His board seems to work, I just don't have the time to get the firmware piece to the same level that you developed it to.
Would it be possible to use your firmware with his board?
[RIP] 2001 E46 M3, Tilton Triple Disc Clutch, JRZ RS2 (750/650), ST-40 332mm front BBK, BW TA16 Square 18x9.5, RE-71R 265/35R19, Redish Motorsport Plates, Mason X-Brace, Mason Front Strut Bar, RaceCapture Pro MK3 w/custom Raspberry Pi Dash.
Jump to top eacmen is offline   Reply With Quote
Old Sat, Jan-11-2020, 09:42:53 PM   #72
NZ_M3
Reputation: 0 NZ_M3 will become famous soon enough
Hi Tap!!
Good to hear from you!
Do you mind sending me the files so I can be the repository for carrying this project onwards for everyone!
For now if we have your permission to use the existing firmware then it’ll definitely push this project further faster ����
Cheers
Jump to top NZ_M3 is offline   Reply With Quote
Old Sun, Jan-12-2020, 01:11:02 AM   #73
tap
Reputation: 0 tap is on a distinguished road
Originally Posted by NZ_M3 View Post
Hi Tap!!
For now if we have your permission to use the existing firmware then itíll definitely push this project further faster ����
Cheers
Wow just read through! Sorry I wasn't around to send you the Gerbers and save you that time!
If I was moving this forward, I would feel different but as it is I don't have the bandwidth so I am totally fine NZ_M3 if you want to distribute my original binary!
Thank you all!!
I'll send you an email with Gerbers and we can talk about open sourcing the software so other folks can pick up where I was at rather than start over.
Thanks!
Tap
Jump to top tap is offline   Reply With Quote
Old Mon, Jan-13-2020, 03:16:36 PM   #74
SliM3
SliM3's Avatar
Thank you all!!
Thanks!
Tap
Still an invaluable piece of hardware to this day
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Thu, Jan-16-2020, 09:30:52 AM   #75
NZ_M3
Iíve sent you an email Tap a few days ago
Just waiting on your reply!
Thanks!
Old Mon, Jan-27-2020, 05:24:50 AM   #76
Drewster
Drewster's Avatar
Thank you all!!
Thanks!
Tap
I'm also capable and happy to help support/ distribute this
Old Sat, Feb-08-2020, 04:04:29 AM   #77
singh336
Reputation: 0 singh336 is on a distinguished road
Thoughts?
I will definitely do that for you, as far as getting the parts soldered up correctly. Software I couldn't help there.
I'm also in need of a BDM tool very badly. I flash alot of mss52/4 and once in a while one has a bad flash and I cannot recover it everytime, even when shorting pins 37 on each eprom to ground.
Jump to top singh336 is offline   Reply With Quote
Discussing XDFproject BDMblock remake?? in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
