Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > F80 M3 (Sedan) / F82 M4 (Coupe) / F83 M4 (Convertible) : (2015-TBD)
F80 M3 (Sedan) / F82 M4 (Coupe) / F83 M4 (Convertible) : (2015-TBD) Discuss the 5th Generation M3
Old Thu, Oct-25-2018, 09:59:39 PM   #1
TurnerMS
TurnerMS's Avatar
Reputation: 0 TurnerMS is on a distinguished road
Default Turner Motorsport - New F80/F82 S55 Oil Catch Can
New Turner Catch Can for F80/F82
Shop Turner S55 Oil Catch Can Here
The Turner F8x M3/M4 S55 oil catch can was designed with a strategically positioned 4 chamber baffle system with an added easy drain feature. The intent behind this design was to offer the most effective oil/air separation while being incredibly easy to maintain. The included drain kit allows you to route the drain hose to a mounted location near the belly pan of the vehicle making it convenient to empty at oil change intervals.
Modern day emissions regulations require the use of a closed crankcase ventilation (PCV) system to recirculate combustion blow-by gases from the crankcase back in to the intake to be burned. Unfortunately, these blow by gases contain water vapor (which is a byproduct of combustion) and pick up oil mist from and the windage cloud and cam lubrication system as they travel through the crank case. Due to less than 100% effective air/oil separation in the stock PCV system, some oil mist and water vapor gets carried back to the intake tract and over time cause oil deposits in the intake manifold, intake ports, and on the back of intake valves. All will eventually lead to poor performance and reduced fuel economy, and the presence of this oil mist in the intake charge may even increase the risk of engine-damaging detonation.
With forced induction, track use, and/or extended high RPM usage, these symptoms increase as the factory PCV system is overwhelmed, and a catch can becomes a must for your F8x M3/M4 S55.
Features:
6061-T6 billet machined body, anodized black for lasting protection and appearance
Strategically positioned 4 chamber baffle system maximizes oil / air separation
Knurled and black anodized oil dipstick makes inspecting oil volume of reservoir clean and simple
Sealed with a pre-installed o-ring
Includes 2.5mm allen key to remove baffle plates for cleaning
Engineered to create multiple changes in the direction of airflow within the separator to cause oil droplets to fall out of suspension before exiting the catch can
Closed / recirculated design reduces oil ingestion and promotes cleaner emissions and odor-less operation
Valved drainage system - no removal of can necessary to empty
Call or email us today! 800.280.6966 or info@turnermotorsport.com
Email: info@turnermotorsport.com
Phone: 1-800-280-6966 press 1 for Sales and tell them James sent you
Turner Motorsport the leading source of high performance BMW parts and BMW accessories in the USA since 1993
Jump to top TurnerMS is offline   Reply With Quote
Discussing Turner Motorsport - New F80/F82 S55 Oil Catch Can in the F80 M3 (Sedan) / F82 M4 (Coupe) / F83 M4 (Convertible) : (2015-TBD) Forum - Discuss the 5th Generation M3 at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
