Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Old Sun, Feb-20-2005, 05:44:14 PM   #1
emfollin
Reputation: 0 emfollin is on a distinguished road
Default Reprogramming factory keyless entry
Someone on here started posting on how to reprogram the keyless entry but he didn't finish. How do you reprogram it? I bought the car with the keyless entry inopt. The light flashes on the fob but it does not unlock the doors.
1997 BMW ///M3 - Sold
2001 BMW ///M3 - Sold
Jump to top emfollin is offline   Reply With Quote
Old Sun, Feb-20-2005, 07:01:59 PM   #2
Sirius
How many licks..
Sirius's Avatar
(This is for the 96+ alarms)
Straight out of the book:
Preparation
1. Close all doors, trunk, and hood.
2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot.
Enter Code-Learning Mode
3. Open the trunk and leave it open
4. Open the driver's door and sit in the driver's seat.
5. Close the driver's door.
6. Cycle the ignition switch five times between the 'OFF' position and position 2, (ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initated.
Do not start the engine.
The ignition switch cycling in step #6 must be preformed within 45 seconds.
Register/Delete ID Code(s)
7. Open the driver's door, (remain seated in driver's seat).
8. Close driver's door.
9. Press and release any button on the remote you wish to register into the system. The status LED will shut off momentarily to indicate that one ID code has been registered.
10. Repeat steps 7 through 9 to register the remaining three ID codes.
It is possible for the system to memorize a total of four different ID codes. As a new code is initalized into memory, the oldest code in memory is automattically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from memory, you could initialize the ID code from a newly purchased replacement transmitter four times thereby deleteing the previous ID codes from system memory.
Exiting Code-Learning mode
11. Open driver's door, and exit from vehicle, leaving the door open.
12. Close trunk.
13. Close driver's door. The LED will turn off and the siren will 'chirp' twice.
14. The initalization procedure is now completed; test all remotes to confirm operation.
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Sun, Feb-20-2005, 07:25:08 PM   #3
DOUGYKIM
Estoril Member!
DOUGYKIM's Avatar
Reputation: 0 DOUGYKIM is on a distinguished road
Related question:
Is there a way to program the alarm system to flash parking lights upon arming/disarming. My alarm only chirps, but does not flash parking lights...only the litle red led on the remote.
Thanks.
'99 Estoril/Black
directed at porschetech...
Originally Posted by porschefan1013
yesh...you look absolutely amazing sitting in that chair right now.
Jump to top DOUGYKIM is offline   Reply With Quote
Old Sun, Feb-20-2005, 08:34:50 PM   #4
Sirius
How many licks..
Sirius's Avatar
No, that option is not available on the OEM alarm for the E36.
97' M3. '10 R6.
Old Sun, Feb-20-2005, 08:38:39 PM   #5
DOUGYKIM
Estoril Member!
DOUGYKIM's Avatar
Darn...thanks for the reply.
'99 Estoril/Black
Old Sun, Feb-20-2005, 09:01:40 PM   #6
emfollin
This didn't work for me, I have a '97 with the alarm. The alarm works from the remote, If I hit and hold the lock button, the alarm goes off in panic mode but the door still do not lock or unlock. When I was entering the code-learning mode, I did not hear the siren chirp once.
Old Sun, Feb-20-2005, 10:34:08 PM   #7
Sirius
How many licks..
Sirius's Avatar
I always found programming the remote to be the most tricky thing to get done.
Sometimes I had to turn the key on/off more than 5 times, but it did it after a few tries.
97' M3. '10 R6.
Old Sun, Feb-20-2005, 10:38:47 PM   #8
emfollin
Alright, and after you do that, you open the door, shut the door and hit one of the 2 buttons, open the door, shut the door and hit the other button on the remote fob?
Old Sun, Feb-20-2005, 10:57:59 PM   #9
Sirius
How many licks..
Sirius's Avatar
Once you enter the programming mode.. you do all this, for each key fob.
So, once you have one key fob programmed, open/close drivers door, hit button on other key fob.. repeat for each fob.
97' M3. '10 R6.
Old Sun, Feb-20-2005, 11:11:46 PM   #10
emfollin
Oh, alright gotcha...I only have one key fob..so after I've done it once, then get out, shut trunk and then shut door....one more question, is the siren chirp like immediate after doing it the 5 times and do I leave the key in the ON position while registering the ID code?
1996, entry, factory, keyless, reprogramming
were keyless entry only with factory alarm? mrk E36 M3 (1992-1999) 0 Tue, Feb-20-2007 03:53:23 AM
Keyless entry watchman E36 M3 (1992-1999) 5 Tue, Aug-22-2006 03:54:59 AM
Keyless entry in '98? Titanium99 E36 M3 (1992-1999) 5 Thu, Nov-10-2005 04:57:14 PM
keyless entry brownMPOWER E36 M3 (1992-1999) 4 Thu, Feb-10-2005 05:38:07 PM
reprogramming keyless entry brownMPOWER E36 M3 (1992-1999) 4 Mon, Nov-01-2004 12:32:21 AM
Discussing Reprogramming factory keyless entry (1996+ and on) in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
