Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted > E36 / E30 - Parts for Sale/Wanted
E36 / E30 - Parts for Sale/Wanted Use this section to post parts for sale or wanted that are related to the E36 or E30 only.
Old Thu, Oct-02-2014, 05:51:27 PM   #1
ApexRaceParts
Default ► APEX |Redesigned and Reinforced Wheel Studs
It's A Good Time To Upgrade Your Studs
Redesigned APEX wheel studs feature an improved shoulder design to reduce stress risers and stud failure. 75mm and 90mm versions are available with a true bullet-nose race tip for faster wheel installs and a cleaner look, or with an easy to install hex head.
What's New?
The Bullet Nose
Don't compromise on safety and quality to get the stud style you want. Most affordable wheel studs today only offer a hex head version. Saving a few minutes during the install is great, but most racers want a true bullet nose tip. We've brought back the bullet nose design and give you the option to pick your preference at no added cost.
The Beefy Shoulder
Typical wheel studs have no shoulder to seat with the hub. Those studs are cheaper and easier to produce, but can result in new threads being cut into the stud as they are tightened. APEX's new wheels studs were engineered with a beefy, tapered shoulder design, allowing for a consistent and flat surface to secure to the hub. This feature helps eliminate stress risers that can lead to stud failure in most other designs. This feature helps eliminate stress risers that can lead to stud failure in most other designs, and will serve as a visual indicator that your studs have been properly secured during the installation process.
Lug Nuts Included
No need to order hardware separately. All studs are finished in black, and lug nuts are available in either a black or silver finish.
Studs vs. Standard Bolts
Less Wear
Wheel studs replace your OEM lug bolts by simply threading into your car's hub. Once installed they do not need to be removed when changing or removing wheels, which preserves the threads on your car's hubs. They also guarantee proper thread engagement, as you can see how many threads were engaged during install.
Less Time
No more time spent trying to line up lug holes while holding wheels up with your feet. Studs make it easy to slide the wheel on and leave it there while grabbing the hardware. Lug nuts easily slide on and off the end of the stud, and can be started by hand with little-to-no effort.
Use Any Spacer
All spacers require extended-length hardware to be used safely. With our extended-length studs, you are no longer required to buy a bucket full of various-length bolts for use with different size spacers. Our 75mm studs support up to 12mm spacers, and our 90mm studs support up to 25mm spacers.
Available Sizes & Options
M12x1.5mm 5 lug kits with 75 and 90mm lengths and Hex or Bullet Nose tips. Silver and black finishes are available
M14x1.25mm 5 lug kits with 75 and 90mm lengths and Hex or Bullet Nose tips. Silver and black finishes are available
M12x1.5mm 4 lug kits for E30s with 75 and 90mm lengths and Hex or Bullet Nose tips. Silver and black finishes are available
Photos
Ordering and Contact Information
Jump to top ApexRaceParts is offline
Rate Seller View Rating
Old Thu, Oct-16-2014, 01:28:12 AM   #2
racea911
Reputation: 0 racea911 is on a distinguished road
Default Re: ► APEX |Redesigned and Reinforced Wheel Studs
When were these redesigned?
Jump to top racea911 is offline   Reply With Quote
Old Thu, Oct-16-2014, 09:07:25 PM   #3
David@ApexRaceParts
David@ApexRaceParts's Avatar
The studs were redesigned over the summer, and the first batch of them arrived to our facility at the time of this thread's creation.
Old Thu, Oct-16-2014, 10:10:44 PM   #4
racea911
So should I be concerned heading into turns 8 and 9 at 120 mph at Big Willow on the old (inferior) design studs I got from you this summer?
Old Thu, Oct-16-2014, 10:16:16 PM   #5
David@ApexRaceParts
We did not have any issues with the old studs under race conditions in the past. The redesign was done to reengineer certain features of the studs, and you can replace the studs with the newest version this coming summer since studs are a consumable item that is recommended to be replaced after every track season.
Old Fri, Oct-17-2014, 12:02:50 AM   #6
jzehren11
Reputation: 0 jzehren11 is on a distinguished road
just ordered mine today along with a set of EC-7s!!
Jump to top jzehren11 is offline   Reply With Quote
Old Fri, Oct-17-2014, 01:58:55 AM   #7
blizzard424
blizzard424's Avatar
Reputation: 0 blizzard424 is on a distinguished road
Assuming only street applications, how long would you say you can drive on a single set of studs?
Jump to top blizzard424 is offline   Reply With Quote
Old Fri, Oct-17-2014, 07:16:03 PM   #8
David@ApexRaceParts
Even for street applications, we would recommend a yearly replacement of the studs.
Old Thu, Oct-23-2014, 05:32:28 PM   #9
robb1887
Reputation: 0 robb1887 is on a distinguished road
Any way to order without nuts? Just looking for studs, and this is a good deal
Jump to top robb1887 is offline   Reply With Quote
Old Thu, Oct-23-2014, 07:21:49 PM   #10
David@ApexRaceParts
Absolutely, give us a call at 925.245.0773 and you can order the studs individually instead of as a full kit.
Discussing ► APEX |Redesigned and Reinforced Wheel Studs in the E36 / E30 - Parts for Sale/Wanted Forum - Use this section to post parts for sale or wanted that are related to the E36 or E30 only. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
