Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > Other BMW M Models > M Coupe/Roadster (1997-2002, 2006-200?)
Old Mon, Sep-15-2014, 06:08:05 PM   #1
Custom Performance
Custom Performance's Avatar
Reputation: 0 Custom Performance is on a distinguished road
Default ***Custom Performance Single Step Headers for the Z4M***
Custom Performance Innovations Single Step Headers for the E46 M3 and Z4M. Unlike any other…
You can reasonable expect +12 to +15 HP and 10 to 12 LBFT of torque. With some additional mods like the CPI drop-in filter and a good set of under drive pulleys - and a TTFS tune - you're looking at +20 HP and +15 to 18 LBFT torque.
$1,195 - includes FREE shipping and FREE header installation kit.
CLICK HERE to place your order.
CPI Stepped Headers with CPI RTX on E46 M3 (We have a Z4M RTX as well)
Final run on same M3 with the following mods:
  • CPI Single Step Headers
  • CPI Rasp Terminator /Crossover (RTX)
  • CPI resonated section 2 (one-off prototype)
  • CPI Drop-in Panel Filter
  • Active Autowerke Underdrive Pulleys
  • Active Autowerkes Gen 6 Muffler
  • Denso Iridium Spark Plugs
  • Fresh Valve Adjustment
  • TTFS Tune
If you have been waiting for a reasonably priced, high quality stepped header – well your wait is over. Introducing the CPI Single Step Headers. These headers have been a long time in the making. We had an initial prototype set of stepped headers about this time last year. I did not post much about them since they were the first set and to be honest, not up to standard (out of the box). With some modifications, they we installed on a dedicated track M3 (that was completely stock), dyno tested, and spent the season on the track. I have dyno graphs but suffice to say, the track M3 put down 297HP and 247 LBFT of torque. Typical stock M3 number are ~280HP and 237TQ - so, approximately +15HP and +10TQ (not bad). No initial fitment issues of after a full season on the track.
Back to the drawing board, made some tweaks, and went looking for another manufacturer. After what seemed like forever, we found a manufacturer experienced with headers and we now have a high quality single step headers.
Custom Performance Innovations Single Step Headers for BMW E46 M3
Key Features:
  • The CPI Single Step headers are all 321 stainless steel (with satin finish instead of high polish) and all joints are TIG welded.
  • The single step design is unique in that the lead pipe is fitted into trailing pipe (design change over first prototype). Other stepped header designs swedge the end of the lead pipe and fit it over the trailing pipe. The CPI Single Step design provides for increase exhaust port scavenging and smoother exhaust flow.
  • The 3-way merge pipe is fitted into the exhaust collector pipe (design change over first prototype). Other header merge pipes are swedge at the end to fit over the exhaust collector pipe. The CPI 3-way merge design provides for smoother exhaust flow into the collector pipe.
  • The primary pipes are integrated with the flanges so that there is no edge, lip or other exhaust flow obstructions at the engine exhaust port (design change over first prototype).
  • Two exhaust collector flanges (one fixed and one loose) that will connect to OE section 1 or any after market section 1 with the OE flange configuration
  • Two O2 bungs on each header and one EGT bung on bank 2 header.
Unique Design Aspects:
Lead pipe (1.65” (42mm) OD) fits snugly into trailing pipe, which has a 1.78” (45mm) OD.
3-way merge pipe is fitted into the exhaust collector pipe (which is 2.33” OD).
Primary pipes are integrated with the flanges and have a 1.56” (40mm) ID which is slightly larger than the 1.52” (38mm) ID exhaust port on the engine head. The header gaskets also have a 1.56” ID so they mate perfectly with the header flanges.
Some other random pictures:
Jack
BMW M3 Performance Parts
We know the parts - not just the part number
For questions, quotes, or inventory checks...
Call or TXT me @ 540.903.3405
Email @
sales@custom-performance.net
FREE SHIPPING ON EVERYTHING
Visit our website - Custom-Performance.net
Jump to top Custom Performance is offline   Reply With Quote
Old Mon, Sep-29-2014, 10:21:23 PM   #2
autom3otives
Reputation: 0 autom3otives is on a distinguished road
Default Re: ***Custom Performance Single Step Headers for the Z4M***
Jack,
How do these compare to the Agency Power headers? I already have the AP headers on my car paired with your Euro200R and Evolve tune, wondering if stepping up to these will be worth it.
Thanks.
1989 M3 | 2001 M Coupe | 1985 190E 2.3-16V
Jump to top autom3otives is offline   Reply With Quote
Old Mon, Sep-29-2014, 10:28:11 PM   #3
Custom Performance
Originally Posted by autom3otives View Post
Jack,
Thanks.
You would definitely pick up some low and midrange torque and a little HP at the top end. As a repeat customer, I can certainly work out something with you. Shoot me a PM.
Jack
Email @
Old Sat, Oct-04-2014, 04:06:46 PM   #4
Dee514
Dee514's Avatar
Reputation: 0 Dee514 is on a distinguished road
Tibet
Do not hesitate to purchase these if you are in the market for catless headers. You will not be disappointed and the price point is great.
I purchased these at the last group buy and finally only had time now to complete the install.
Fit was perfect, as if was an OE piece. No issues at all during install (just don't mix up the 02 sensors and is the perfect time to put all new ones in). No check engine lights/codes with a catted section 1.
Subjectively, I do not feel any loss if any power/torque low end...possible a very slight increase. Above 3k, it really wants to pull. Needless to say it put a smile on my face.
Next step is the TTFS dyno tune at the end of the month.
Jump to top Dee514 is offline   Reply With Quote
Old Mon, Oct-06-2014, 10:50:37 AM   #5
Custom Performance
- UPDATE on LONG TERM TESTING -
Car #175, driven by Steve Ladderman, just completed his second full season with the CPI Single Step headers. He finished 5th in class (GTS3) and 10 overall in the Eastern National Championship Race. Looking forward to season 3!
Jack
Email @
Old Wed, Oct-08-2014, 03:59:44 PM   #6
QwikFlip
Reputation: 0 QwikFlip is on a distinguished road
Thanks to CPI for the support! The headers have been flawless. I have put these through the ringer with both sprint races and an entire endurance series last year. They keep delivering no matter what I throw at them!!
Jump to top QwikFlip is offline   Reply With Quote
Old Thu, Oct-23-2014, 10:58:02 AM   #7
Custom Performance
Some pictures from a recent install.
Jack
Email @
Old Wed, Nov-19-2014, 05:56:49 PM   #8
TTFS
TTFS's Avatar
Reputation: 0 TTFS is on a distinguished road
Great work as always Jack
Jump to top TTFS is offline   Reply With Quote
Discussing ***Custom Performance Single Step Headers for the Z4M*** in the M Coupe/Roadster (1997-2002, 2006-200?) Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
