Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Old Thu, Nov-25-2004, 02:15:39 PM   #1
300ZXNA
300ZXNA's Avatar
Reputation: 0 300ZXNA is on a distinguished road
Default Replacing '95 HVAC backlighting
First off, you will need the new bulb. It is 1.2 watt bulb that looks like a christmas tree bulb which I got two off of ebay for a few bucks. To replace, first pull all 4 knobs off of the HVAC, they should not require any forcing or undo strain. Underneath the two largest knobs are two small phillips head screws. Undo these the faceplate should then just pull off. The bulb will be top dead center on the exposed facade though just the tip of the bulb will be sticking out, and you may need tweezers to help grasp it. I was able to carefully pull it out with my fingers, pop the new bulb in and reverse the steps to put the faceplate back on. Should take all of 5 minutes. Anyway, just wanted to write this up in case anyone searches for it in the future . . .
1995 Metallic Pearl Yellow M3
M50 Intake/Euro HFM/24# injectors/JC Chip/Schrick Cams
3.2l '99 Motor with OBD1 electronics
Cosmos Cold Air Intake
ZKW Ellipsoids w/ DDE Plus
Stromung Exhaust
M-Tec Illuminated Chrome/Leather Gearshift Knob
Understeer.com SSK/UUC Red TME's/DSSR w/ERK
Toyo Proxes T1-S fr:235/40/17 r:245/35/17
Euro 3 Spoke Steering Wheel
Stainless Steel Brake lines; Solid brake guides
Ground Control Koni Coilover Kit
Urethane RTAB's and FCA bushings
E46 Style dual 10 spoke 17" rims
X-Brace
Coming Soon:
UUC Swaybars
Triple Gauges
Valentine One
Twin Screw SC
Jump to top 300ZXNA is offline   Reply With Quote
Old Thu, Nov-25-2004, 05:42:30 PM   #2
Sirius
How many licks..
Sirius's Avatar
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Backlighting Woes: Gauge Cluster, HVAC, Clock, Head unit Simann E36 M3 (1992-1999) 11 Wed, Sep-12-2007 04:41:04 AM
hvac problem. please help drew03 E46 M3 (2001-2006) 3 Tue, Feb-07-2006 11:25:55 PM
Hvac Rattle? teb74 E36 M3 (1992-1999) 5 Sat, Jan-28-2006 12:16:28 AM
Instrument Backlighting relay? chip4 E36 M3 (1992-1999) 2 Thu, Mar-27-2003 07:51:14 PM
Backlighting emn120_dude E36 M3 (1992-1999) 2 Sat, Aug-17-2002 01:40:38 PM
Discussing Replacing '95 HVAC backlighting in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
