Old Thu, Nov-07-2013, 08:58:18 PM   #61
Default Re: My highly unusual (weight/practicality focused) stereo project
Originally Posted by admranger View Post
Ian, how does the new sub compare with the "old" one?
BTW: for those who need a breakout box, PXA-H100, or a JL XD700/5, please PM me. I've decided to go a different, lower tech (like me) route with my X5's sound system. All are almost new with little use. Ian is correct, there is a (very) noticable difference between having the PXA-H100 on and off. Substantial.
It actually sounds way better. The last sub wasn't the optimal impedance for the amp, so I didn't get everything out of it that it could have delivered. This sub is less powerful, but I can use it 100% correctly, with the result that it sounds significantly better overall
Old Sat, Dec-07-2013, 01:06:39 AM   #62
deepinya
ZCP IB CINN
deepinya's Avatar
Reputation: 0 deepinya is on a distinguished road
Are you running all this off stock battery/alternator?
Jump to top deepinya is offline   Reply With Quote
Old Sat, Dec-07-2013, 01:58:05 AM   #63
Smaller battery than stock, stock alternator.
... I wouldn't be surprised if I had less power draw than stock, though.
Old Sat, Dec-07-2013, 11:14:00 PM   #64
deepinya
ZCP IB CINN
deepinya's Avatar
How many amps are you running? 2 or 3?
I love Polk speakers and also have 2 stealth subs to install. I see the Polk tweeter but are you using that other tweeter looking thing too?
Old Sun, Dec-08-2013, 02:16:48 AM   #65
Two very small amps (lighter than the 2 factory amps I removed).
I'm just using the Polk tweeters. Two Polk mids, two Polk tweeters, one <5 lb sub. :P
Old Sun, Dec-08-2013, 02:34:10 AM   #66
deepinya
ZCP IB CINN
deepinya's Avatar
Oh ok so one amp to run the speaker set and one to run the sub?
What kind of power are they putting out?
I know you are trying to keep it lightweight but Im wondering if I do something slightly bigger will it draw too much from the battery/alternator. I know in my old car I had to upgrade just to handle one 4x125 (rms) amp.
You pretty much have the same speaker sets Im gonna be using...I may add the other stealth sub. How good does that one sub sound?
Old Thu, Dec-12-2013, 05:09:13 PM   #67
bullet0770
bullet0770's Avatar
Reputation: 0 bullet0770 is on a distinguished road
Hey Guys,
Not too many threads or information on E46 M3 audio upgrade (Looked in different forums). After reading few other forums I got some basic information and might need some help from M3 forum members here.
I want to upgrade audio in my car. I have an E46 M3 Coupe with basic Hi-Fi, Navigation and Bluetooth.
What impedance are our stock speakers ? I read 4 ohms and somewhere I read 2 ohms.
Can I use Stock amp if I use same impedance speaker ? I want to use 4 ohms speakers all around and want good sound. My budget is $200 per pair for speakers, as of now I might buy 2 pairs and one amp ($300/$400). Also one sub if I can install without using trunk space. I am not adding anything now just want to play stuff from my iphone via Bluetooth.
I am thinking of buying DLS speakers, 4 Channel Apline amp and maybe alpine processor. What all things do i need. Any help would be appreciated.
Thanks
Jump to top bullet0770 is offline   Reply With Quote
Old Mon, Jan-06-2014, 11:48:22 PM   #68
admranger
Registered troublemaker
To get it to fit into the stealthbox housing, I had to grind ~.5cm of metal off the outside of the speaker, ~.5cm of material off the inside of the stealthbox, and make new mounting holes inside the stealthbox, but it all worked out.
I should have done this with my Hybrid Audio Technologies (HAT) 6.5 Imagine speakers I put into the X5. It would have necessitated me buying a bench grinder () and actually taking the time to do it ().
Instead, I lopped off the top of the X5 speaker door mount and made a mechanical connection to it and the HAT speaker using the HAT speaker mountain holes and screws. Good news is that it sounds fantastic! Bad news is it wasn't as neat and tidy as your install, Ian.
19 X3M40i, Carbon/Oyster
18 330i xdrive GT, Mineral White/Black
Old Sun, Feb-09-2014, 07:01:20 PM   #69
deepinya
ZCP IB CINN
deepinya's Avatar
Hey Obi, any chance you can make a video of what that one sub sounds like inside the cabin?
I have some stealth boxes but need speakers and would be great to actually hear it in action. Surprisingly, I couldnt find any videos on youtube.
Old Mon, Feb-10-2014, 12:25:17 AM   #70
I don't think that would be overly useful, honestly. Using the sound processor, I could bias that to sound however I wanted. Recording as is would just show my personal preference.
You semi local to pa? Could check it out in person and set it however you like.
Discussing My highly unusual (weight/practicality focused) stereo project in the Audio/In Car Entertainment (I.C.E.) Forum - Place to discuss sights and sounds. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
