Old Sun, Jul-10-2011, 08:02:58 AM   #41
Default Re: Comprehensive programmable option thread
Evolve showed me how they turn on the shift lights, and it wasn't anything like this-- it was a recode through the binary of the ECU. I suspect someone would have noticed by now if that turned on shift lights. Then again, I would have through that someone would have figured out M track mode before now as well!
That said... most of these things are reversible without any issue, you could do it and get back to us!
Yep, the shift lights are controlled by the DME. I once got them by flashing an SMG tune onto my DME, but since my car isnt actually SMG, it got stuck in limp mode. I'm not sure what you need to change in the binary, but without knowing how BMW calculates the checksums, I don't think we can use winkfp to flash non-factory tunes. The interfaces themselves should be capable of flashing anything to the DME, so theoretically a good programmer can write a program that uses our cables to read and flash custom tunes and bypass the checksum.
NCS expert cannot enable (or disable for that matter) the shift lights. As you guys discovered, that line in the AKMB is for the smg LCD and error indicator
Old Sun, Jul-10-2011, 06:25:08 PM   #42
opey
opey's Avatar
Reputation: 0 opey is on a distinguished road
I don't really know what to do with that. I like the completeness of it, but I don't have space to edit it into the original posts....
isnt that the same info thats in the PDF that you posted in the beginning of this thread?
also any of you guys know what i have to do to get my one touch UP to work again? it works for down but not up, i have to pull the switch all the way to the 2nd position and hold for the windows to go up. and its verified to be active thru ncs expert. i also have inpa and dis44 available to me
04 IR/IR 6spd
sold =(
Jump to top opey is offline   Reply With Quote
Old Mon, Jul-11-2011, 05:33:57 PM   #43
Flow
Flow's Avatar
France
Your problem might be the window top position "memory".
You should try to get your window all the way to the top and then hold the button for at least 5 seconds (after the window went all the way up).
This should "teach" the system where the upper position is.
Then you should be good to go with the one touch up!
At least it is like that on one of my cars, and I wouldn't be surprised if it was the same on the e46.
Keep us posted!
2004 M3 TiAg / LSB SMG
Old Mon, Jul-11-2011, 10:38:41 PM   #44
opey
opey's Avatar
Keep us posted!
i think ive tried this before and it didnt work, but ill try it again. most german cars dont respond to these simple tricks lol
04 IR/IR 6spd
sold =(
Old Wed, Jul-13-2011, 11:58:29 PM   #45
opey
opey's Avatar
Keep us posted!
ok so i fixed it. turns out it wasnt anything programming related. after some heavy googling, something i read set off a lightbulb in my head. there are sensors in the top gasket for the pinch protection, i read about somebody who had them come loose or something. this reminded me about when i swapped my a-pillars, i saw a wire on each side that was plugged in but went nowhere and the end was taped. i had no idea what it was for and forgot about it. now when i bought the car, the gaskets were both messed up and the dealer replaced them for me before i picked up the car. 2+2 = they never plugged them in. too lazy to remove the pillars i guess, or maybe they tried and couldnt get the screws out. anyway i plugged them in and it worked perfect, no reset or programming needed. feels great to have them working now lol
04 IR/IR 6spd
sold =(
Old Thu, Jul-14-2011, 06:13:31 PM   #46
Dave B
M3 collector
Dave B's Avatar
Italy
[B][U]Instrument Cluster:
-Cluster offset. The instrument cluster reads high by about 7-8%, this can be adjusted, so it's closer to actual speed.
Whoa, wait a minute - my speedo is off a full 7% even with OEM tire sizes? (and even more with slightly smaller diameter?) How did I never know that?
No wonder the cop didn't care when I went by him at 80.
Isn't there also a setting for allowing one-touch up to continue to work even if the door is open?
Old Thu, Jul-14-2011, 06:26:09 PM   #47
casper3t
casper3t's Avatar
Reputation: 0 casper3t is on a distinguished road
yeah there is, when the door opens you can roll the windows up and down regardless without having the key in the ignition
FH_NACH_TUERE_AUF :Power windows when door is open
'02 Euro Tuned ///M3 6spd Carbon Black cover with a layer of dust and Grey Int.
Jump to top casper3t is offline   Reply With Quote
Old Thu, Jul-14-2011, 08:41:07 PM   #48
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
Is it possible to activate triple blink indicators on 03.5 cars?
Old Thu, Jul-14-2011, 08:46:06 PM   #49
Keegan99
Keegan99's Avatar
Reputation: 0 Keegan99 is on a distinguished road
Out of the factory, unfortunately not. If you've received a new OEM LCM since '06, then yes.
I have a 2005.5 and can't do it. Friends with 06's can. I believe some of the later '05's can as well, though I haven't confirmed it personally.
Jump to top Keegan99 is offline   Reply With Quote
Old Mon, Jul-18-2011, 09:00:04 PM   #50
ltbong
Reputation: 0 ltbong is on a distinguished road
Which parameter needs to be modified to turn off the cluster offset?
2006 Interlagos/Cinnamon
Tools for Loan
MIS RTAB Tool
http://www.m3forum.net/m3forum/showthread.php?t=406072
OEM VANOS Timing Tool
http://www.m3forum.net/m3forum/showthread.php?t=406073
Jump to top ltbong is offline   Reply With Quote
Discussing Comprehensive programmable option (coding) thread in the Coding and Tuning Forum - Discuss all avenues of coding and tuning here! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
