Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Closed Thread
Old Tue, Apr-20-2004, 04:26:03 AM   #11
astan100
astan100's Avatar
Reputation: 0 astan100 is on a distinguished road
LOL...okay guys, no more worthless posts.
Any more SERIOUS differences that people don't know about?
99 Cosmos M3 with Modena Interior.
Mods: Carbonio CAI,Bilstein Struts/Shocks,SS Brake Lines,K-mac Camber Plates, Stellar Alarm
In the Market for: Ellipsoids + HIDs (R.I.P- Bosch Housings with 4300k HID's.), a ZKW fog light bracket...not sure which side yet.
Recently installed: New set of Rear Bilsteins with RE RSMs
To be installed: UUC Red TME's, Alpine Head Unit/Sirius
Current annoying M3 problems: wind noise from badly aligned windows
Jump to top astan100 is offline
Old Tue, Apr-20-2004, 08:52:03 AM   #12
Sebasel
Sebasel's Avatar
Reputation: 0 Sebasel is on a distinguished road
Originally Posted by 99DakarM3
Aluminum hoods and doors I believe - on the Euro's.
only on the GT editon !!!
HARTGE 18"rims(summer) HARTGE 17"rms (winter), HARTGE exhaust, HARTGE springs,HARTGE ecu 7800rpm, HARTGE strutbrace front, HARTGE swaybars (front and rear), HARTGE springs, HARTGE floormats HARTGE thrunkspoiler, GT-Xbrace, Rearstrutbrace, Sportkoni's, 6000K angeleyes, Delensend, 6000K HID, K&N airfilter, Goodrich stainless steel-braided Teflon® brakelines, Zimmerman brakedisks, M3 Carbon engincover, Carbon frontspoiler, 3,2liter airbox
Jump to top Sebasel is offline
Old Tue, Apr-20-2004, 08:55:13 AM   #13
Sebasel
Sebasel's Avatar
Originally Posted by astan100
I can't seem to find any stuff prior to moving forums, so I'll just post what I know.
Pretty much, Euro M3's have all the engine differences that we talked about before, but they have some cosmetic stuff too.
For instance, US headlights are notoriously bad. They are cheap plastic that illuminate like 20 ft. in front of you. People buy the EURO headlights because they're made of glass and use projector lenses. Though they are still halogens, they are way better. Umnitza, one of our beloved sponsors sells euro lights if you need them.
Euro M3's mostly come with clear corners, side markers, and tailights too, but I'm sure on that one. Somone suggested that the bumpers are slightly smaller and better contoured as well, but don't quote me.
They have an adjustable steering column, which I would really really want.
They have a 6 sp tranny instead of our 5. Our 5 speed is really just their 6 without a 6th gear which is why we are always revving so high on the highway.
They had available SMG I, but I don't know what years that was available in. The US model didn't have that option until it was SMG II in 2002 for E46 M3's.
Ummm...I'm sure I'm missing a lot of stuff here. Anyone else?
6 speed only , after 1995 on the 3.2 liter M3 !!! (1995~1999) on this model also the clear corners, side markers, and tailights on this model SMG was also available
the 3.0 liter (1993~1995) has a 5speedtranny!!!!!
Old Tue, Apr-20-2004, 12:41:03 PM   #14
WD Pro
1998 M3 Evo (Euro)
WD Pro's Avatar
Reputation: 0 WD Pro is on a distinguished road
Some early Euro Evo's had the ally doors.
Lots of good info on here :
http://www.geocities.com/mhenry_au/info_US_vs_Euro.html
And also on here :
http://www.bmwmregistry.com/model_faq.php?id=15
WD Pro
1998 M3 Evo (Euro)
Techno : Light Grey : SMG
Jump to top WD Pro is offline
Old Tue, Apr-20-2004, 03:52:04 PM   #15
Extrav.Dreams
Beacon in the Darkness
Extrav.Dreams's Avatar
Reputation: 0 Extrav.Dreams is on a distinguished road
"Our 5 speed is really just their 6 without a 6th gear "
Then why won't the Euro tranny fit on the NA?
-Sebastian
8/95 Cosmo M3 - One BAM
Jump to top Extrav.Dreams is offline
Old Tue, Apr-20-2004, 04:25:47 PM   #16
Edgy
Constantly Learning M3 and M5 Owner
Edgy's Avatar
Reputation: 0 Edgy is on a distinguished road
Wink And Now we'll never answer this question again, right?
If we want to be totally comprehensive, note the first gen Euro had an S50 engine that put out 286 HP, while the 95 NA version had same designation, but only 240HP.
For 96-99, US engine gets it's own designation, S52, and a little more torque.
How is the Euro-spec M3's 3.2-liter engine (S50 B32) different from the previous version (S50 B30)?
When creating the 3.2-liter M3 engine, BMW M relied upon much of the experience it had gained when designing the V12 engine for the McLaren F1 supercar. In the end, the S50 B32 incorporated the following improvements over the S50 B30 engine used in the original Euro-spec E36 M3:
-Increased bore to 86.4mm (from 86.0mm) and lengthened stroke to 91.0mm (from 85.8mm) for a total capacity of 3,201cc (from 2,990cc)
-Increased compression ratio to 11.3:1 (from 10.8:1)
-Advanced BMW/Siemens MSS50 engine management system able to compute 20 million instructions per second
-Double VANOS continuously variable valve timing on both intake and exhaust strokes
-Lightweight pistons
-Improved dual-mass flywheel
-Graphite-coated conrods
-Larger inlet valves
-More efficient intake and exhaust systems
-Second oil pump
The result of these changes boosted horsepower from 286 hp (DIN) at 7,000 rpm to 321 hp (DIN) at 7,400 rpm. Maximum torque also increased from 236 lb/ft at 3,600 rpm to 258 lb/ft at 3,250 rpm. This was the first street-legal BMW engine to achieve over 100 hp per liter.
How is the North American 3.2-liter M3 engine (S52) different from the 3.0-liter (S50 B30 USA)?
Unlke the Euro-spec S50 B32, the S52 powerplant is an evolution of the standard production M52 engine. However, it incorporates the following changes over its S50 B30 USA predecessor:
-Increased bore to 86.4mm (from 86.0mm) and increased stroke to 89.6mm (from 85.8mm) for a total displacement of 3,152cc (from 2,990cc)
-More finely balanced camshafts
-Valve lifters, springs and spring seats with reduced mass
-Revised intake and exhaust systems
-OBD II (On-Board Diagnostics, version II) compliance
-Horsepower unchanged at 240 hp (SAE) at 6,000 rpm
-Torque increased to 236 lb/ft at 3,800 rpm (up from 225 lb/ft at 4,250 rpm)
NOTE: E36 M3s equipped with the ZF five-speed automatic transmission are rated at 225 lb/ft of torque at 3,800rpm.
The E36 M3 3.0 is the original BMW Motorsport (later called BMW M) version of the E36 3 Series. Available as a coupe, convertible or sedan, it uses one of two 3.0-liter S50 engines, both based to some degree on the standard production M50 powerplant. The European S50 has individual throttle bodies and a more complex cylinder head, while the U.S.-spec S50 more closely resembles the normal production M50 engine. All E36 M3s also have a BMW M-tuned chassis and unique cosmetic items both inside and out. Unlike its E30 M3 predecessor, the E36 M3 was not designed primarily for competition use, but rather as a road-going GT car.
BLUE HEAVEN:
Interlagos 2006 M3, AutoLogic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Conforti/Shark tune. MRegistry listing here
Jump to top Edgy is offline
Old Tue, Apr-20-2004, 05:13:16 PM   #17
astan100
astan100's Avatar
Good point Extrav. I heard that the ratios were the same for 1-5 though pretty much.
Wow, we're getting good stuff! Keep em' coming.
Old Tue, Apr-20-2004, 05:24:21 PM   #18
SG_M3
#56 JP M3
Reputation: 0 SG_M3 has disabled reputation
Who said it doesn't fit? It bolts up fine.
Sean
- 98 M3 EB/BLK
Jump to top SG_M3 is offline
Old Tue, Apr-20-2004, 05:44:45 PM   #19
99DakarM3
99DakarM3's Avatar
Reputation: 0 99DakarM3 is on a distinguished road
I though you needed a new driveshaft as well? Anyone?
99 Dakar Yellow M3
ASC Delete
FDK
x-brace
BenFer CAI
UUC EVO 3 w/ SS RK3
UUC Pullies
S-03s
Jump to top 99DakarM3 is offline
Old Tue, Apr-20-2004, 08:36:03 PM   #20
SG_M3
#56 JP M3
You do need a shortened driveshaft. You can buy a euro one, or shorten your stock driveshaft.
Sean
- 98 M3 EB/BLK
Closed Thread
Differences Us x Euro spec? No_name E46 M3 (2001-2006) 1 Sat, May-03-2008 02:23:40 AM
Euro Trim Differences? findley E36 M3 (1992-1999) 8 Sat, Dec-31-2005 05:25:54 PM
What are all the differences between Euro M3 and US version? Choson1 E46 M3 (2001-2006) 34 Mon, Jun-07-2004 12:10:09 AM
E36 differences SoupRSam3 E36 M3 (1992-1999) 23 Sat, Feb-28-2004 02:15:25 AM
Engine differences between US and Euro cars.. tms217 E36 M3 (1992-1999) 6 Thu, Feb-19-2004 04:05:44 PM
Discussing (E36) Why is there a Euro M3 and what are the differences in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
