Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Old Thu, May-07-2009, 09:29:46 PM   #1
ceres2
Reputation: 0 ceres2 is on a distinguished road
Default Replace Check Engine Light
1997 4 dr M3, 171,000 original miles still does not burn drop of oil!
Hope someone can help on this. My codes are all clear, car runs great BUT the car will not pass Connecticut emission tests because the check engine light does not light! Its dead or burned out. My problem is I cant replace the bulb. I tried to remove the Insturment cluster but cant get it past the wheel. Does the wheel have to come off? Does anyone have instructions on this fix?
Jump to top ceres2 is offline   Reply With Quote
Old Sat, May-09-2009, 02:59:20 AM   #2
BeeMDoubleYouM3
Reputation: 0 BeeMDoubleYouM3 is on a distinguished road
Im not sure how it works in CT, but in NY they plug some type of OBDII reader into your cars computer. Even with the bulb removed, the CEL will still come on if they scan the computer. Just because the light isnt physically on, it will still pop up once the car is scanned. If its only a visable inspection, then go ahead and pull the bulb out.
Jump to top BeeMDoubleYouM3 is offline   Reply With Quote
Old Sat, May-09-2009, 11:01:34 AM   #3
badquenga
Detailer - San Diego
Reputation: 0 badquenga is on a distinguished road
Well that's not helpful. He said he doesn't know how to take the bulb out.
I don't have the link [edit], but there are a few threads with people replacing the amber look of the lights where the completely rip open the cluster. Those should help.
The checking the CEL isn't just about the codes. It's about knowing the codes are there. If your CEL doesn't light, what use is it? It wouldn't pass here in Cali either, but then again...not much does.
Jump to top badquenga is offline   Reply With Quote
Old Tue, May-12-2009, 05:25:53 PM   #4
ceres2
Thanks Guys but I guess it going to the Dealer...Had it plugged into a analysis system computer at a shop, and the light came on for a brief time then went out. So its not the bulb..we did not get a single code. So it probably some sensor screwed up or wiring problem..
check, engine, light, replace
Check Engine Light: Engine Temp Cold o8OneLight8o E36 M3 (1992-1999) 17 Fri, Oct-03-2014 01:49:01 AM
Check Engine Light, Red Oil Light awilley Faults, Fixes and DIY 0 Wed, Mar-18-2009 03:54:02 PM
Check Engine Light Montyb//M3 E36 M3 (1992-1999) 16 Tue, Jul-29-2008 07:38:47 AM
Check Engine light and one green bar service light.. Balboa E36 M3 (1992-1999) 2 Sun, Jun-22-2008 12:15:14 AM
Check Engine Light? - Check Control OK kevnmurphy E36 M3 (1992-1999) 6 Sat, Jul-23-2005 05:45:23 PM
Discussing Replace Check Engine Light in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
