Old Fri, Jan-04-2008, 01:15:12 AM   #1
USM17N
USM17N's Avatar
Reputation: 0 USM17N is on a distinguished road
United Kingdom
Default SMG transmission problem
Hi Guys was wandering if anyone has come across this problem, was driving in s5 as normal in 3rd gear, all of a sudden the gear number started flashing, as though the SMG had shifted to neutral on its own, then i got the bell chime, (the one you get when the cars in gear and you open the door) anyway i turned the car off and back on and it still wouldnt go into gear either S or A mode, everytime i engaged a gear the numbers would flash and then the bell chimes, as i was close to home i decided to push the car (with the help of a few friends) as the car was in motion i engaged the gear and this time the number didnt flash, so i pressed the throttle and all of a sudden its fine, picked up the gear and drove me home, any ideas WTF just happened???
Jump to top USM17N is offline   Reply With Quote
Old Fri, Jan-04-2008, 01:19:13 AM   #2
BMW F1
Where to now ???
BMW F1's Avatar
Reputation: 0 BMW F1 has a reputation beyond reputeBMW F1 has a reputation beyond reputeBMW F1 has a reputation beyond reputeBMW F1 has a reputation beyond reputeBMW F1 has a reputation beyond reputeBMW F1 has a reputation beyond repute
Sounds a little bit RANDOM to say the least.
Try resetting the system and just continue to monitor it.
If it does happen again, ring your SA ASAP.
Best of luck with the it.
Ada///M.
BMW///M3CSL
Teh STi can nevar lose!
Jump to top BMW F1 is offline   Reply With Quote
transmission problem klenky bujold E46 M3 (2001-2006) 4 Tue, Aug-12-2008 02:36:04 AM
Transmission problem? mj1133 E46 M3 (2001-2006) 5 Fri, Jan-04-2008 03:04:10 AM
Is this a transmission problem? dreaminbimmers General BMW Discussion 3 Tue, Oct-24-2006 03:47:32 PM
Serious problem with SMG/Transmission/Computer theroon E46 M3 (2001-2006) 9 Sat, May-06-2006 03:10:20 PM
possible transmission problem...? swarsx E46 M3 (2001-2006) 9 Tue, May-24-2005 08:45:16 PM
Discussing SMG transmission problem in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
